selling my skyline as is due to an accident rb25det engine 120000k's car has got slotted rotors dba 4000 all round fmic 3 and a half stainless exhaust muffler damaged but bolts off exhaust all running gear is still on the car selling for $3000 call or text me on 0423967556 or 0432062780 located in melbourne
  • Replies 210
i was in chappel street with a mate and u know dandenong road and chappel street that massive intersection i went though a orange light and 3 quarters though in the intersection the light turned red and this bitch coming from dandenong road hit me at 90k's and my car spun around and hit another car in the end the cop reckons its my falt coz im driving a turbo car its a sports car im a p plater and all the other shit its a hoons car so i got the blame and he fined me so i lost the car but the main thing is me and my mate are alright
hey mate, i'll stick with the deal.. im at docklands during the day and mitcham at night.. how do you wanna arrange it? plus i cant msg some error occur.. :P
Edited by Fido_
fark epic. if she ran the red its her fault regardless of what car u drive because ur not claiming on your insurance. :P
That'll buff out. All you need is a shamwow....
Are you going to be parting this car out?
If so I'm interested in the wheels.
If not, dang :blink:
selling a complete RHS door with door mirror door trim door handle ect its perfect condition not one scratch or dent in it also selling RHS guard and bonnet all in perfect condition
RHS door complete $400
RHS guard $150
bonnet $300
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
