  • Replies 210
selling full 3.5" exhaust from turbo back stainless steel comes with dump pipe high flow cat middle section and cannon with silencer $600
RB25DET Complete Engine is up for sale $2500
comes with
Engine loom
ECU
Coilpacks
Turbo
AFM
Alternator
Power steering
AC compressor
Fuel rail + injectors
Exhaust manifold
Intake manifold
Throttle body
Starter
The lot and only done 123368k's
Edited by perry_r33
i was in chappel street with a mate and u know dandenong road and chappel street that massive intersection i went though a orange light and 3 quarters though in the intersection the light turned red and this bitch coming from dandenong road hit me at 90k's and my car spun around and hit another car in the end the cop reckons its my falt coz im driving a turbo car its a sports car im a p plater and all the other shit its a hoons car so i got the blame and he fined me so i lost the car but the main thing is me and my mate are alright
i new i saw this car somewhere before lol . i saw you that night there was like 4 ambo's and shit yeah ?
stupid bitch . sorry to here man im pretty sure it was you tho it was late at night yeah ?
yea man it was late like 12 or 1am there was a few ambo's and i was with a mate
aslong as your alright man at the end of the day its just a piece of metal, a very sexy and meanigful piece of metal lol
sorry to hear again mate.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
