Right im now up for a gbox rebuild and i dont wanna stay with standard gears. I've done research on sau and for some reason quite a few ppl have sumthing to say about par gearsets but wont say it. Im considering buying the 1st to 4th straight cut synchro box and would like to hear some comments on what ppl have to say about them. Plain and simply dont be scared if you have run a par gearset and sumthing failed or a bad experience plz tell me about it i dont wanna fork out 5 grand for a gbox only for it to be a waste of time.
thnx everyone
https://www.sau.com.au/forums/topic/308638-par-gearsets/
thnx everyone
dont waste your $$ Simon...OS Giken is the best option for your car.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092611
ok people if you know of blown gearsets etc list the car, type of box if original box or different or any other details that may need to be included like what type of racing they were doing or wat the driver was doing at the time it failed. i dont wanna hear that you know of one i wanna hear real stories.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092913
well as far as i know, the pulsar boys over east have been using par gearsets in there sr20det powered sss pulsars etc and have had no problems
rwd, dont know anyone whos running one but they r a tad expensive comparing to genuine OS giken
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092984
in australia for the os giken gearset synchro helical $4199 ebay unfitted/ even worse $5499 just jap unfitted. par straight cut synchro unfitted $3800. tell me how that is more expensive?
the cheapest i found overseas minus postage for the os giken set is actually $3748.
im aware i posted $3400 in post 4 but didnt realise it was in american dollars not aus.
Edited by skylinekid
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5093183
got a second opinion today off one gearbox diff company ..... was informed dont bother they have had many gboxs blow gears strip teeth etc due to being poorly made and they dont know wat warranty means there. so yeh looking bleek for these gearsets unless theyve picked up there act over the last yr which i doubt. gahhhh ne other opinions ppl
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094036
i can get a 2nd hand box for 1000bucks off a mate here but with running near upto 600hp i want sumthing i dont have to replace in 10000kms or less like this one. the box i pulled out of the car was whining sumthin terrible i pulled it apart yesterday and found that the front gear on the cluster shaft has worn off all the case hardness and is starting to go through the actual gear. i got the box rebuilt minus synchros just all bearings 10000kims ago and got all gears etc cryo treated. there has to be a cheaper relaible option then spending 10g on a ppg dog box.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094238
Im afraid you will either have to fork out for a PPG gearset or keep putting in stock boxes.
Im on my second stock box. They are stronger than you think.
It also comes down to how you drive the car, you wont be using 600hp all the time.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094307
my OS saw 600hp a fair bit and was pretty bloody bulletproof...Terry says it all comes down to correct initial assembly and regular maintenance of synchro's that allows them to last.
Terry is the gearbox worlds Jedi master.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094339
I'd say gear wear means the oil cant cope. I use Redline MT-90, but in your special case you should probably give them a call and explain what's happened with the gear wear and ask what they recommend, maybe one of the shockproofs.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094661
yeh im not gonna put the gearbox back in how it is so it doesnt really matter about the oil. its worn the cluster shaft that much that the car sounds like its runing straight cuts. sounds cool but not good wen u realise one day its gonna fail. im just gonna get a secondhand box and probably run either redline or a new oil ive heard of neo synthetic 75-90 very expensive but apparently the ducknuts of oils.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094854
yer my stocker box lasted heaps of time on the street pushing it real hard without a care when slamming gears, but soon as i hit the drags the first pass i swear i took it easy into 3rd and bang smashed the teeth of it. This is a 32gtr box in a 1750kg stagea with a 2.7L running 560awhp. I was suprised how long it lasted on the street the way i was driving, but for some reason the drags were a different story even running the same street tyres.
I went ppg straight cut dog option and its brilliant, fast shifts are simple and firm, its drivable on the road but maitainance costs would make it not suitable and the whine is pretty damn loud except for 4th gear.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5095100
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
