Its more the sudden impact that will destroy your gearbox, take it easy when changing gears! what clutch have you got? a Nismo coppermix will help if you have the bucks. It cost me over 10g for a ppg so think about it.
whenever i change gears i always allow time for the synchro to catch up never slam it through gears. theres been nuthin fast enough to warrant slamming the gears. even a 570hp maloo ute he had about 20 car lengths on me wen we both punched it and by the end of third i had about 10 car length on him... he went home with his tail between his legs complaining i threw rocks at him.... I said "well next time stay infront" lol
True, and think about what would happen if the shock loading broke the oil film - no more gear against gear sliding and the forces of the now gripping gears would rip the teeth off, as the force would be radial instead of tangential (just my guess).
With over 86,000 thousand threads on the good oils and many different opinions there's not much talk on build tolerances or how hard they push their cars, most of todays oils are very advanced.
I was running over 350kws at all 4s with a standard gearbox with 10 year old oil trouble free, I added a triple plate clutch (higher impact) with fresh Motul oil, flicked the Motec switch down to 270kws and with the 1st caining Bang! gearbox no more, Redline will tell you they have the best oils in the world along with all other brands, Test... add MT-90 to finger then hit with hammer, outch! some tune shops race GTRs with standard gearboxes with twin plate organic clutches.
You really need to spend the Dollars on the full package to have any real luck or modify your driving style.
Agreed, the original point was mainly about wear and film strength, which is very much oil dependent. Getting as much backlash out of the system through tight build tolerances is also crucial. Out of interest - was the triple plate solid or spring center? Solid centers must be be murder on drivelines.
ive got a sprung centred hks gd max twin plate never broken a box just worn shit out. the hks twin is now slipping so giving it to jim berry most likely to do a carbotic rebuild and up the clamping load. will see how it goes they claim tho heavy clutch's are murder on synchro because of the mass that is spining takes longer to slow down mainly os giken clutches i was told unsure why but yeh.
Exedy Hyper metal series spring center, a good clutch with no slip at all, was just too tuff for the old girl but no probs for the ppg.
any one got any info bout the ppg helical gear sets?
also with the OS gear sets u need to purchase sum parts from the series 3 GTR boxes right? so whats the cost of those parts?
wen i enquired bout the series 3 bit they told me $590. unsure if they use the revised synchro's for the ppg set.
i have had no experience with PAR gearsets...
but when i spoke to them not to long ago with what they could do for me they mentioned something about 12month warranty if they assembled and installed the gearbox.
So thats something to think about
yes but people that i rang around and spoke to about them said that par and warranty are words that shouldnt be mentioned together. but ive never seen evidence yet of a par gearset in a skyline failing they have there own 9.8sec drag car not aussie built but still if it work it works. im very keen to try a set and punish it to see if it breaks or last quite a while plus they offer cooler sets then ppg like a straight cut synchro set... i think thats pretty mad lol
  • 1 month later...
Yes i snapped my box last week, and im thinking of getting a PAR, The owner of Hills motorsports said to me his installed around 150 in the past and his has only heard of one snapping 2nd gear and the car was doing 850HP, So i think i might take my chances. If you talk to another gearbox company most of them will bag out the competetors anyway
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
