R33 RB26 head, all covers, HKS 280 pro cams, tomei type 2 springs and buckets, tomei cam cap studs, some porting, machined and fitted rear oil drain, machined for cam clearance, $3200- SOLD (unassembled - can arrange to have it asssembled)
HKS T51r ported manifold and HKS GT wastegate
$1900 SOLD
Endless Plenum $2200 NEW SOLD
Billet Throttle body to suit $550 NEW SOLD
Hi guys,
I have bought and stored the following parts for a while now and realised that i probably wont be needing it. Bought it off the infamous BU5TER. The above head flowed 450RWKW nicely through an auto box. cam covers included. Sorry no flow test have been conducted.
Manifold has also been cermaic coated and includes a dump pipe to suit gtst. It is V-band, however HKS make a adaptor plate to use with T04 based turbos
Plenum is a work of art - just check out greenline to see the current price then add freight. Hypertune base theres off this. Also the Billet throttle body is to match this - dont ask me what diameter it is either :D b/c i have never measured it.
Prices are as above please pm any serious request - unfortunately items are in DEEP storage in the garage and a simple pic is not possible unless i get some serious interest. Items are located in syd.
Cheers
Steve
Edited by HKS26T
  • 1 month later...
  • 1 month later...
Hey mate I'm realy I terested in your gtr head for the 2500 what is included the head buckets caps studs rocker covers ?
Do u have flo charts of the head as well
  • 3 weeks later...
how much u want for the plenum
Manifold Cermaic Coated
PAID $1900 NOW $1750
Endless Plenum PAID $2200 NOW $2100
Billet Throttle body to suit PAID $550 NOW $400
Edited by HKS26T
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
