hey guys
got a rb25det. about to reove my standard turbo and put a 3071r on.
just a couple of questions,
i have an oil line made up for the oil feed for the turbo. it does't have a restrictor in it. is this alrite?
i was told that 3071r's have in built in oil restrictors. . what about the size of the oil feed line?
as for the water lines, i was thinking of cutting the standard water lines and barbing the ends of them. and running braided hoses clamped to the original lines for the turbo. are the inside diameters of the standard water lines good enough for cooling a 3071r/
cheers
https://www.sau.com.au/forums/topic/309112-garrett-3071r-oil-and-water-lines/
You have 7/16 UNF for oil feed, which your stock is M12x1.25
Water fittings are M14x1.5 which your stock water fittings are in M18x1.5
Oil drain bolt pattern is in T28 (1.5inch) your stock is in 2 inches
New oil drain adaptor is mast. withes threads you can either tab all the thread sizes to suit your stock lines or get new lines made. We normally drill and tab them into stock thread.
that ebay kit seems to be the go.anyone tried them? crap quality?
do yo need a restrictor in the oil feed? the current lines that i have for the turbo ( damaged) seem to be the same inside diameter as standard. they don't have an oil restrictor
are the stock water lines the right size aswell ( inside diameter). . cause i might cut my standard water feed, and hose clamp the braided turbo lines that i already have to the cut water feed.
tapping it wouldn;t be to bad
tao do you do any oil and water line kits?
cheers
Most of the ebay lines has rubber in it. For water they are ok. For oil You need the teflon braided line. We normally machine our bearing housings to suit stock water lines, so I can only supply the oil feeding line for $80.
You can get your water lines made up at local Enzed or Pirtek stores for about $150. Or just drill and tab new thread. Cost lot less.
You don't need restrictor for the BB unit. They already got 20 thou restrictor on their oil feeding pin.
check the ebay feedback, it seems to be good, noone with fitment issues for the GT3076 RB25 kits and a few sold.
message the seller and ask about materials used, highly doubt it is cheaply made. alot of items that seller has are OEM.
Hint , many SR20 OE water cooled turbos use the same size banjos and bolts as the Garrett BB turbos in the GT2554R to GT3582R range .
Sometimes import wreckers will sell them to you for not a lot of money .
All you really need the steel water lines for is to get far enough away from the turbos heat for rubber hose to survive reliably . High pressure (EFI) fuel hose makes good rubber water line material .
The Nissan banjos/bolts are compact and look factory because they are . Just make sure the water supply line runs uphill to the turbo and the outlet one uphill to wherever it connects to the system .
Cheers A .
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
