Hey Guys,
For sale are parts listed below which have come off my car as im continually upgrading to bigger things!
Any Questions please dont hesitate to contact me
Pictures to follow,
Standard 6 GTR Injectors – One in need of rebuild - $200
Standard GTR fuel Pressure regulator - $80
Standard GTR fuel pump $50
Bosch 040 Fuel Pump - $100
Standard GTR oil pump - $100
Standard GTR ECU - $200
Standard GTR Coil Packs - $100
Coil Pack Looms GTR - $60
Standard GTR cam gears - $50
Standard GTR ceramic turbos - $400
GREDDY Intercooler 70x30x100 - $500
2 Pod Filters - $100
ARC R32 GTR airbox - $400
11 row 17x24cm oil cooler - $100
GTR Original cam cover - $150
Original GTR Fan - $20
Standard GTR calipers and rotors - $350
OS Giken twin plate clutch – in need of rebuild - $200
2 x Blow off valves - Aftermarket - $60
R32 GTR standard exhaust - $150
Mines Titanium headers GTR - $500
Titanium cat back GTR - lemon sliced - not sure what brand - have to check size - $500
Exhaust Elbow – Multi angle – 10cm - $20
2.5 inch Catalytic Converter - $50
Exhaust muffler insert – $20
Titanium De Cat Pipe – $60
HKS Boost gauge - $100
Nardi Signature steering wheel - $200
Edited by josh23457
https://www.sau.com.au/forums/topic/309125-massive-gtr-others-clearance/
  • Replies 48
Re the Titanium cat back GTR, could you please advise size and what it suits
Cheers
il have to check tomorrow night but memory i think its 3inch at the cat then swells to 3.5 inch right through....
What size are the collector on Mines Front Pipe.
If it's 3.5" I'm mega keen on them.
Cheers
Grant
hey,
they are 6cm at the dumps and swell to 7.5 at the collector before the cat...
can send you better pics if you send me your email address..
josh
CHecked the ti exhaust tonight
The size of the ti catback is a 3.5inch decat which then straight after goes into a 4inch straight through
the front pipes are 6cm at the dumps and 7.5 at the collector when they go into the cat....
hey,
josh
Crap, was hoping for 3.5" to match my HKS 3.5"
Thanks anyway.
Cheers
Grant
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
