Hi everyone!
For sale I have the following parts located in Sydney
RIPS Plenum to suit RB25: I never actually fitted this to any of my cars while they were running but it is in good condition and the intake flanges matches the rb25 gasket. I am unsure if there is a difference between NA and Turbo manifolds. I have a spare throttle body here too which came with it you can have
$450 SOLD
R33 Strut tower bar
$50
RB26 Cam covers and valley cover in QM1 white
$300
RB26 Front timing cover in black- Have 2
$50
Z32 AFM and plug
$SOLD
Nismo 750cc injectors for rb25 on rail
$SOLD
Genuine Greddy intercooler kit inc alloy piping and cooler, cold side pipe has trust style BOV
$400
Apexi Power fc for r33 GTST with hand controller
$SOLD
R33 GTR turbos with standard dumps- taken off the new motor I bought for my race car. approx 60 000kms of standard boost
$500
Standard coilpacks from the r33 GTR motor
$50
Twin Turbo pipe for RB26x 2 sets
$SOLD
RB26 exhaust manifolds
$150
Just Jap Rear camber arms- brand new never fitted
$160 pics further down
Oil cooler kit
$100
More parts and pics if you scroll down
some pics:
Power FC for R33 GTST with hand controller
Z32 and plug
Nismo injectors on rb25det rail
all the mods were done around 10 000km ago so egverything is in top condition I need to degrease the fuel rail but thats about it.
located in glenfield in sydney.
here are some pics of the 26 timing cover, i have 2 for sale
also the remaining twin turbo pipes and rb26 manifolds
some brand new just jap r33/S14 rear camber arms $150
Just jap oil cooler kit $SOLD
Factory 32 GTR intercooler rubber pipesx4- $50
Pipe to shorten intake piping and get it out of the way for a nice turbo setup $40
note it is currently painted silver.
more stuff to come keep checking back
I will get some pics when its not raining, the cooler is still on the car atm, i have to take the greddy plenum off to put the factory cooler on, and i'm not able to pull it off til next weekend unless someone wants it urgently.
It is a spec m kit i bought brand new, with a bov installed on the hot side under the guard. I have had it for a few years but the car has only done 10 000 k's.
does have a tps on it which plugs straight in. I'll take a pic of the throttle body on the weekend im not sure which type it is. Just came with the plenum lol but it is a nissan part
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
