Ok now got the wheels from my dad its now in my garage and this wheels came from subaru forester 5 stud
wheels have bit gutter rashes and 2 excellent tyres and 2 good tyres
i will drop the price to $450 TAKE IT AND GO
hi brett
i iwll send you a PM of the offsetlater im still at work yes willing to post
cool just trying to work out details, the fairlane pcd is 114.3 but i can get adaptors to fix that, just need to work out the offset now.
