Hi Stagea folk,
Im new to the forum, well posting anyway. I picked up a 97 Stagea RS4 late last year and am loving every minute of it. Well except filling it with fuel.
Whats the deal with the filler opening? It seems too narrow for the pump nozzles. When i fill up I cant simply squeeze the trigger and fill it up at full flow. After spending nearly 10 minutes yesterday and giving up at 40 litres I thought I might ask some questions. Im putting this down to one of the quirks you have to live with when driving an import, but is there anything that can be done to remedy the situation? Or does everyone simply deal with it?
Cheers
Brett.
ps I did try the search button with numerous combinations but got no where. Hopefully this thread might help other newbies in the future.
Hey Brett, welcome to the forums!
Is your car a freshly-imported one, or one that's been in the country for a while? If it's a fresh import, you might want to make sure the importer/compliancer has changed the nozzle in the compliancing process (assuming it's even different from Japanese nozzles, anyway). I believe it's one of the requirements of the process, so it should have been done.
I have definitely had the trouble you are talking about, both in my previous s2 (1999 model) and my current M35.
My first thought when I read the title was the same as everyone else - "stop filling up with diesel" lol...just kidding.
Different servos seem to give different results. I find most of the ones I go to regularly here are fine (all BP), but there are some where you really have to experiment with different angles to get the pump nozzle in. Then its another job trying to get it back out when you're done. I've had the most trouble out in the country when doing interstate trips.
The other problem is that because its not a fantastic fit, you sit there pulling the trigger in slowly until it goes click, click, click, and keeps shutting off. Most of the servos I go to now are ok and I can pull the trigger fully in, but its very frustrating when thats not the case - trying to get a good compromise between actually getting petrol in the car and not standing there for half an hour trying to fill up.
lol... that constant clicking is because your nozzle it too deep in the hole.... try pulling it back about an inch, doing so will change the angle and allow a higher flow.
(and yes, I realise how that sounds :huh: )
Yeah I'm sure changing the filler neck thing is a requirement for compliance, I guess it could be possible that it wasnt done or the wrong item was somehow used though?
As others have said though, just experiment with holding the pump nozzle at different angles first, thats more likely to be the cause of the problem.
Is this something that happens at every petrol station you go to?
haha nah definately not using diesel. Im not that noob.
Im using either BP ultimate or Caltex Vortex98 and I havent been able to get either to find "the sweet spot". I was turning and adjusting the nozzle in every concieveable direction yesterday and just couldnt get it to flow steadily.
As far as I know Im the 3rd Aussie owner so its not freshly imported.
Thanks for the help though. I guess I'll just keep fiddling with the nozzle.
Cheers
Brett.
Edited by SUBL1ME
Yeah my 34 does the same, drive's me nuts. Specially at a busy servo when u want to fill up and the people behind you think your being a wanker and going slow on purpose.
I to am yet to find the "sweet spot" with the bloody thing.
Not all car's have the restrictor thingy your talking about, as most car's i think allready have the small opening to only fit unleaded nozzle's in, i think it was more they were fitting anti syphoning things in? Well from what i can remember.
Just so as you guys know, it is not only your cars that have this prob.
My wifes Magna is an absolute bitch for this... I can only have the nozzle about half way in to allow the full flow from the bowser.
Then when it is full, it coughs and splutters up a heap of fuel through the breather holes which runs down the paintwork and splashes my hand.
I hate the damn thing.
Wost. Fuel filler. Ever.
Not a bad car besides that and the whole FWD thing....
I had the same problem with my series 1 when i got it. Pretty sure it is the anti siphoning flap stopping flow. get inside the rear wheel arch and detatch the rubber connector that is held on with 2 hose clamps. Cover the pipe that goes to the tank and mash the flap out with a screw driver. Thats what i did and it worked for me.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
