i can get one of my mates to ask his 700+ facebook friends to storm that page. but most would try and add you, being the typical northern suburb fullysikksss.. that okay?(wont ask him to till you say yep or nop)
lol facebook friends gah.
"I have over 700 friends...on facebook."
"And what did you get up to on friday and saturday night?"
"Stayed at home on the computer."
hahaha yeah i know. hate it when some from school or work adds you and you dont even know them, and when you reject and they ask why.... umm because i dont know you?
esther. did you win?
true Birds, oh so true :down:
GTR-boy, I dont know yet, haven't been messaged or anything so guess I'll just have to wait it out. I did get in front by 5pm AEST time tho, but the other guy reckons he won at 5pm EDT time. so i dono :)
Rightly so :bunny:
No offence to esther but I hate these popularity competitions haha. Person who's added more people to facebook wins a competition that judges their artwork :)
Rightly so :blink:
Get your facts straight. It's a viral marketing campaign used to create product/brand awareness run by a MAJOR software vendor - Computer Associates. The aim was to make ANYTHING creative and get the most likes by any means. As usual you have to add your often misplaced opinions...
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
