  • Replies 76
For a GT-RS on a RB25 it seems to be coming on fairly late at 3600rpm.
The peak looks about right so there is still room for more power earlier when that is sorted. I'd expect it to be all in about 500rpm or so earlier.
I think he is concerned that excessive blowby will develop if I go any further HP wise.
Apparently the standard exhaust manifold starts to become a restriction at this level too, ie excessive exhaust pressure/heat buildup. Correct me if I'm wrong.
dont think so dude... i had my old car making 290rwkw on the standard manifolds and it was all good... no catch can either :D
he must want you to have it as a precaution rather than anything else...
Edited by usmair
The manifold is not an issue at that power level.
I would have a look at the wastegate as a reason for the lazy-ish boost response.
So thats just a matter of fitting a tighter spring, right? Would the stock BOV have anything to do with this ie leaking?
dont think so dude... i had my old car making 290rwkw on the standard manifolds and it was all good... no catch can either :)
How long were you running that power level? How do you know you didnt have blowby if you didnt have a catch can?
I dont think you will get much more than 250rwkw out of a GTRS on a stock RB25. But it should have really good response.
If the stock bov was the issue you would have issues with high amounts of air not with response.
Mine GT-RS runs 256rwkw @ 14psi.
However, it has headwork, HKS cams, Plazaman plenum aswell.
Nice results! Bet you are happy. Gets boring quick tho :P
Edited by Granthem
Standard everything else, RB25, Powerfc, injectors, FMIC, exhaust, and GT3076 with 56trim, 0.6 comp cover, a 0.63 IW rear housing, 18psi of boost. Full boost at about 3100rpm.
Boost was on steady here to stop traction loss. Came on hard though, and at around 3000rpm as I said.
Set up the 3076 properly, and it will not be laggy.
Er.. while thats annoying to see it spooling earlier than my smaller turbo, its not entirely relevant now that I have a GT-RS :P
I am pretty happy with the way it drives though, much smoother coming onto boost.
Unfortunately after 6 months of being f**ked around by yellow sticker, getting hail damage, and having it stuck at the workshop for 3 weeks getting tuned guess what.. its been raining all day yesterday and today, which means I can't really test the acceleration properly.
since we're posting set ups...
heres mine... stock neo motor, un opened except for poncams type b's, has AM performance stainless steel steam pipe manifold with custom collector, 3076, tial 44 gate, fmic, 3.5 inch exhaust, nistune, 600cc injectors and runs 50/50 ethanol/bp98
running 16 psi too... its crazy to drive and is very VERY responsive. torque chart was on the wrong read out when they printed it but it makes around 550 nm torque at the wheels.
Check the wastegate preload SoFreshSoClean. If the actuator has some play in it, crack the 10mm nut and go a turn or two!
This wont need retuning because the AFM compensates for the extra air and adds fuel right?
Gonna have a look-see tomorrow. If its stopped raining. Which it hasnt. :)
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
