hey guys long time no speak,
have been really busy lately so thought i would come and say hi!!!
and my piston rings have gone in my r33!!!
i have been trying to find on this forum a guide or something??
im gonna have to change em my self as i cant afford stupid garage prices to rebuild it etc,
can anyone help getting a full engine manual for rb25det in r33?
all help would be appreciated guys thanks for your time
https://www.sau.com.au/forums/topic/310682-piston-rings/
im also prepared for pistons, cylinders bored, crank re done, is there anything else i should expect?? or while ill have the engine out worth changing?
put in some RB26 resized STD conrods with ARP bolts, an oil pump (nitto), the exhaust guides will probably be flogged out so they will need replacing, some decent valve springs, the usual stuff like cam belt and pulleys etc and if you can afford it a decent harmonic balancer. It will be good for around 500hp at the treads.
Edited by Swiper the Fox
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5118852
Sorry mate can't get the file off me mate. Doesn't want to transfer it over MSN to me, being a weak prick. It's a 120mb PDF file hehe.
However! Because I'm awesome, here's a direct link to an online one...
http://paulr33.skylinesaustralia.com/manua..._engine_man.pdf
Also, lol @ the link location...... was under ya nose the whole time, mwahahaha
:D
Edited by stormtrooper
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5119237
thats brilliant thanks soooo much, i was thinking about signing up to tafe and learning japenese hahahahaa
im pretty sure this topic will be going for a loooong while while i rip out the engine, ill try and take pics when i can as well hahahaha.
ill try and change over as much as i can in the engine, thanks for the shopping list guys, bit of a pain really the cam belt has only done 20,000kms lol had it changed not long ago!!
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5119405
hey,
sorry to bring your world crashing down
but unless you have experience with vernier calipers, micrometers, ACL plastigage, measuring bearing clearances, .. can dial in camshafts etc
then its probably better to take it to somewhere like a hyperdrive in malaga or similar workshops
you might pay a small premium but the job will only be done once, not like f***king up and learning from your own experiences then spending double
because you forgot to check something or prime the oil pump on first turnover. not saying your a muppet, it's just that engine reconditioners
etc spend a decent amount of time learning their trade and if anyone could do it then they wouldn't be in business.
i have had a few mates rebuild engines even tradesman but they were no engineers and the motors in question were lucky to last 20,000km
in any case, dont just smash a second hand wrecker engine in there!!
do it right first time
good luck mate!
Edited by dave_rb20
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5120375
thats what has also been running around in the back of my mind!!!!
i was thinking about taking the engine out then paying someone to rebuild it? all the garages say a fewk is just labor taking the engine in and out, i think that might be a better opition, i can change headgaskets and things like that but as u say, im defo no mechanic lol
i might give hyper drive a call and get a price so far all garges are up around $8k :-( the car only cost 13k lol
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5120679
hey man!
you will save money by pulling engine yourself but then you have to deliver and pick it up from reco place...
also your warranty from engine builder may be void this way
end of the day you have to make some decisions
- how much can I afford to spend?
- do I just need it running to get around?
- will I be looking to keep this car for a long time?
- what are my goals with the car? track/drag/drift, street fun, daily run around some hp
another option would be to take it somewhere budget orientated like KYP in welshpool, have a second hand wrecker engine fitted
for 4-5k, then keep your old engine on a stand and build that up yourself over time. there are some good books on the subject
you can get and that way there won't be time/finance constraints.
cheers
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5127481
KYP is a good place to get a 2nd engine
and its unlikely to sell a 33 GTST for 7k with a blown engine
Running ones on carsales/quokka for Series 1 are from 7-8k+ or 11-12k+ for Series 2
*shamless plug* My mate has a 25 block, forged pistons (needs rings) and GTR rods for sale
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5127498
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
