hey guys long time no speak,
have been really busy lately so thought i would come and say hi!!!
and my piston rings have gone in my r33!!!
i have been trying to find on this forum a guide or something??
im gonna have to change em my self as i cant afford stupid garage prices to rebuild it etc,
can anyone help getting a full engine manual for rb25det in r33?
all help would be appreciated guys thanks for your time
https://www.sau.com.au/forums/topic/310682-piston-rings/
im also prepared for pistons, cylinders bored, crank re done, is there anything else i should expect?? or while ill have the engine out worth changing?
put in some RB26 resized STD conrods with ARP bolts, an oil pump (nitto), the exhaust guides will probably be flogged out so they will need replacing, some decent valve springs, the usual stuff like cam belt and pulleys etc and if you can afford it a decent harmonic balancer. It will be good for around 500hp at the treads.
Edited by Swiper the Fox
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5118852
Sorry mate can't get the file off me mate. Doesn't want to transfer it over MSN to me, being a weak prick. It's a 120mb PDF file hehe.
However! Because I'm awesome, here's a direct link to an online one...
http://paulr33.skylinesaustralia.com/manua..._engine_man.pdf
Also, lol @ the link location...... was under ya nose the whole time, mwahahaha
:D
Edited by stormtrooper
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5119237
thats brilliant thanks soooo much, i was thinking about signing up to tafe and learning japenese hahahahaa
im pretty sure this topic will be going for a loooong while while i rip out the engine, ill try and take pics when i can as well hahahaha.
ill try and change over as much as i can in the engine, thanks for the shopping list guys, bit of a pain really the cam belt has only done 20,000kms lol had it changed not long ago!!
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5119405
hey,
sorry to bring your world crashing down
but unless you have experience with vernier calipers, micrometers, ACL plastigage, measuring bearing clearances, .. can dial in camshafts etc
then its probably better to take it to somewhere like a hyperdrive in malaga or similar workshops
you might pay a small premium but the job will only be done once, not like f***king up and learning from your own experiences then spending double
because you forgot to check something or prime the oil pump on first turnover. not saying your a muppet, it's just that engine reconditioners
etc spend a decent amount of time learning their trade and if anyone could do it then they wouldn't be in business.
i have had a few mates rebuild engines even tradesman but they were no engineers and the motors in question were lucky to last 20,000km
in any case, dont just smash a second hand wrecker engine in there!!
do it right first time
good luck mate!
Edited by dave_rb20
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5120375
thats what has also been running around in the back of my mind!!!!
i was thinking about taking the engine out then paying someone to rebuild it? all the garages say a fewk is just labor taking the engine in and out, i think that might be a better opition, i can change headgaskets and things like that but as u say, im defo no mechanic lol
i might give hyper drive a call and get a price so far all garges are up around $8k :-( the car only cost 13k lol
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5120679
hey man!
you will save money by pulling engine yourself but then you have to deliver and pick it up from reco place...
also your warranty from engine builder may be void this way
end of the day you have to make some decisions
- how much can I afford to spend?
- do I just need it running to get around?
- will I be looking to keep this car for a long time?
- what are my goals with the car? track/drag/drift, street fun, daily run around some hp
another option would be to take it somewhere budget orientated like KYP in welshpool, have a second hand wrecker engine fitted
for 4-5k, then keep your old engine on a stand and build that up yourself over time. there are some good books on the subject
you can get and that way there won't be time/finance constraints.
cheers
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5127481
KYP is a good place to get a 2nd engine
and its unlikely to sell a 33 GTST for 7k with a blown engine
Running ones on carsales/quokka for Series 1 are from 7-8k+ or 11-12k+ for Series 2
*shamless plug* My mate has a 25 block, forged pistons (needs rings) and GTR rods for sale
https://www.sau.com.au/forums/topic/310682-piston-rings/#findComment-5127498
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
