Evening guys and gals. I am considering selling my GTR and possibly funding an r35 or maybe a serious r32 build. But for the moment, i am considering EOI's on the current numberplates on the car.
Black background, silver writing, slimline front and back and a perfect fit to the rear bumper cavity of the 33 gtr.
Combination is 33GTRV
Please pm me if you are interested, and as for a price, i have NFI. id at the very least like to recoup my original purchase costs, if thats possible ;)
Cheers, allan
https://www.sau.com.au/forums/topic/310775-eoi-numberplates/
