Hey guys, after a bad experience on the highway ( some idiot left a wheel on the road) I need a few parts.
I am chasing a passenger side front strut complete with control arm and everything as mine is bent bad , without the brakes........
I am in desperate need for this to get me going again so if anyone could please pm me if they have anything i would be greatfull.
thanks
SIC32
https://www.sau.com.au/forums/topic/31082-wanted-r32-parts/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
