  • Replies 199
The thread title says 2-4pm
Is that race time?
When do we need to be there by and do cars have to be checked over before running?
My car will be finished on the dyno at EFI Performance on Wednesday, so hope it all goes well.
Is that race time?
Hey
As todd has not replied as yet ill jump in and help...
2 til 4 is race time, so with this in mind you would want to be lined up at the gates around 1:15pm - 1:30pm as they let you in around 1:45-1:50pm or there abouts...
From the front gate you drive up to the start of the staging area, you will see a couple of people sitting behind a table under a little shed...
You need to stop near them, take your paperwork and helmet to them... They will inspect your helmet and ensure it mets the current Australian standards...
Then you will get your fore arm stamped to show you have signed your forms and they will walk back with you and put a number on you car...
Usually the rear passenger side window (using a white marker, easy to remove the next day)...
After that you drive forward to the front of the staging lanes and wait further instruction...
As for the car/bike, they dont check it over... The helmet is the important one for them, as all our cars/bikes are registered they assume a relative road worthy state is present...
Hope this helps...
whats this paperwork you speak of?
Do we get the required paperwork on the day at the front gate when we get there?
Thanks for info
Yeah, just bring a pen...
You will get it from Todd on the day to fill out while we are waiting at the gates...
Its a simple personal details form and sign at the dotted line...
Just bring a pen, as usually the hold up is people waiting for pens...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
