I'm planning on running antilag on my R32 gtst targa car. I'm running a RB26 throttle setup (using the RB26 injector plate, through to plenum), will the aac valve flow enough air on closed throttle to run antilag properly, or will i have to prop the throttles open/run kicker soleniod/run bigger aac valve?
That thread is useless. This guy is using it for a Targa car and is asking a legit question! I have only used Group N on my car so I cannot help.. Interested in knowing what you find out though
So did you have the throttle jamed a certain % open, or use a throttle kicker?
I'm running a Haltech Platinum Sport 2000
Yeah i opened the throttle to 15% and i use the vipec ecu with cycle idle
The AAC doesn't allow air enough for proper anti lag - your talking 40degrees retard to get boost at idle plus you want at least 2000-2500rpm if not more. I would be selecting another ecu as well - something that has a proven track record in group N - like Autronic or Motec. You really want closed loop boost control as well - to limit overboost. A "throttle kicker" maybe the best way as you only need a small change in tps to get a large change in airflow when you have 6 tb's.
I'm not expecting boost at idle, just trying to bring to take a chunk of lag out of the poor rb20. I'll give it a crack with the aac first, who knows may be surprised. At the end of the day it's pretty easy to prop the throttles open with the rb26 adjustible linkages.
I'm sure the Haltech will be fine, it has closed loop boost, all the antilag settings for antilag retard, fuel, rotational idle...ect. Alot of cars down here (tassie) are running Haltech. I'd rather stab myself in the face than use the Autronic software, and i'm not morgaging my house for a motec.
Hey I dont mean to seem like I am hijacking here. But to get a bigger IAC valve, what would you get?
My stock IAC doesnt have anywhere to go on the current plenum I have. Was wondering if I got a different IAC (brand, shape, size etc), is there one that would just would work with the stock wiring loom. Granted I may have to wire a different plug onto the end of it.
Also is there one that will simply attach via a tube so I can connect it to the plenum via a hose instead of having to get the plenum cut and thread tapped into it to bolt it on?
Sorry about the slight hijacking.
i had this issue so i used a pice of 6mm alloy and made a plate for the alve to bolt onto then i got a 5/8 weld on fitting welded on to the 6mm plate. walla. i can mount the idle valve where ever. its just a matter of plumbing it in.
Ahh ok yeh that sounds like a good idea :no: Should give that a go.
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
