Oooh, this looks exciting..
What class would we fit in Andrew???
It's too confusing.....
Modified Road Cars
Category 2
4. 3001-4500 cc
The only thing that tips us over from standard road cars are the injectors, brakes, adjustable suspension arms and more boooooost. :)
It's on Easter Day, which may mean not many people will turn up - I'm still thinking about it as my kids will never forgive me. I'll be at the track before they wake up. Such a dumb date for it.
Modified Road Cars
Category 2
4. 3001-4500 cc
I'm definetly out, there's no way my family and relatives would forgive me if I were to miss out on Easter Sunday lunch.
What are the organisers thinking???
Would have entered otherwise....
does your car still have its road reg andrew?
CATEGORY 2: MODIFIED ROAD CARS
8.1 Vehicles in this category must be Road Cars (as defined in Regulation 6.2) and presented
in a condition suitable for use on a public road in Australia and must remain in such
condition throughout competition at each Championship Round.
6.2 ‘Road Car’ means an original production car or a production car modified from original
which is capable of being authorised by Government authority (via registration or permit)
for use on public roads in Australia.
Yep, It gets driven to work quite a lot when the trains are crap. :blink:
isn't Greek easter on a different date Jack? My wife's family would actually murder her if she missed easter with them... and now we are married I have to attend too... but I don't do church so I just go along to eat all the fooood :blink:
Unfortunately it falls on the same weekend this year... what a bummer....
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
