Hi Guys
We have a few vacancies for our next skidpan training day on Saturday 17th April.
Our skidpan training courses are conducted at the Attwood training complex near Melbourne Airport. The skidpan is wet and super slippery, to keep wear and tear to a minimum and to facilitate low speed skids.
(This is not the course for you if you are a full-on hektik drift god)
Its a great opportunity to explore your cars limits in a safe and controlled environment. We have an experienced instructor working with you on these courses.
Each session runs for 4 hours with 6 drivers per session.
We run a morning and afternoon session.
Cost per driver is $140
Please contact Tessa to book your position 1300 652 693 or email her [email protected]
You can learn more about our skidpan courses here.. http://driverdynamics.com/skidpan.html
Kind regards
Kev
Im in for arvo session too Kez, I got the last spot.
so excited, first skid pan ever, i'm gonna be so nervous, but really want to learn how my car handles in the wet with hicas and the 4wd system.
You'll have to ring them to find out.
I booked about a week ago. Afternoon session was full but some spots were available for the morning. $50 deposit with the rest payable on the day.
I've actually done it before and its a crap load of fun. Couldnt help myself but to register again. You learn a fair bit. They have water constantly flowing at a few points around the skidpan, along with some really slippery stuff (not sure if its oil/soap/whatever) at two opposite ends.
Should I leave the Kumho KU36s on for this, or resort to the unknown brand of tyres that came with my stockies?
I doubt there will be much wear on the tyres, considering it so wet, but would the semi-slick pattern affect the grip on my front tyres?
ive got Mitchelen pilots on, they are on the wear line on the inside of the wheel because of camber and about 2mm off the wear line on the outside.. im assuming that should be enough tread then....
because im getting new tyres a couple days after this....
Not sure if this is a stupid question, but is this a worthwhile session for a GTR with the attessa system?
I haven't had the car long, so I guess I just answered my own question in terms of gaining a better understanding of the car with the awd system, but other opinions would be appreciated (don't want to deter the topic too much but just one or two opinions will be fine).
If worthwhile, I am definately there (dependant on availability of spots of course).
I'd try it. Sure you might not drift amazingly, but you'll get a good grasp of how your car reacts when cornering and when you lose control.
Besides, isn't there something you can disconnect in the drivetrain that makes your GTR RWD only?
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
