Hi guys,
I'm a new member to this forum. So I still have a lot to learn....?????
Anyway with all these talks about finding and owning a GTR. I was just wondering anyone could give me some hints on their occupations, as with my current job I won't be able to own one until I'm 50. By then I will look like a try hard.
Cheers,
https://www.sau.com.au/forums/topic/31121-whats-one-have-to-do-a-own-a-gtr-r33/
  • Replies 73
I plan to win lotto and buy this hell nice R34 GTR i've seen at a shop in sydney... :( that's the easiest way to do it... i just keep forgetting to buy lotto tickets... lol
i see a lot of drug dealers with nice cars... lol.... hmmm other than that, no idea... lol
I can only concur with Leewah, work hard and save. If price is the motivating factor, go for an R32, they'll set you back around 20-25K (anybody feel free to correct me here). Otherwise if you want an R34, start saving your pennies, and open a managed investment account, stockmarket's gonna give good returns this year :P (just some friendly unsolicited financial advice... geez, my degree does come in handy!)
If you have been working for 6mths or more fulltime than almost any bank these days will give you $25k without too much of a struggle. Then you only need to save another $15k and your home!
Of course, I wouldn't recommend this but hey it will work if you -really- want to get a GTR (and pay $60k for it instead of $40k for it :P)
Argh, argh aaaaarrrggghhh car loans!!!!! Sorry, just had to say that, but those things are evil just like credit cards. :P
I've been there, it's a much better feeling when you own it outright. There's no struggling to make payments, especially with 25K, it'd be at a fair rate of interest too, probably twice that of a house loan.
Does anybody know if they let you mod the car if it's under finance?
Best thing to do is start with something a little more realistic, IE a r33 GTSt.
My plan is spend some money on my GTSt, that way i learn the car/engine etc and get myself a good base of preferred Panel/Paint and Mechanical places.
Then sell the Gtst for around 20K, Goto the bank, show them i have a 20K deposit for it already, borrow 20K easily and pay it off in 1-2 years.
Going from basically nothing to a GTR is not a good idea.
They are very dangerous cars in the wrong hands.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
