might swing past and take a look after I go to the ACT all ford day at old parliment house ...
Finally my Project Turbo laser is going and boosting strong :( so much infact it keeps hitting boost cut ... LOL ... and the car is meant to be on stock boost of 9psi yet boost cut is at 15 ... im a bit baffled
the first pic is of your car, if its zane driving just claim it was you you cant tell the difference with a helmet on.
can actually tell the difference now, reece actually bought his own helmet, its black with a black visor unlike mine which is white with a black visor
Hey Stinkypoo some excellent shots, did you catch any from skylines cutting skids on the pan next door?
Or of my awesome angles *pulls* (read: spins)?
Please....
I only got a couple from each. I was trying something different on the camera.... Some shots worked, others didn't.
Edited by StinkyPoo
Congratulations on getting the out-right course record AGAIN (two times on same day!!! :D ) Michele! Truly awesome stuff to watch in action! :blush:
Glen.
Thanks Glen, although it was taken away from me again LOL
Its about to be taken out of reach of me altogether. The multi winning NSW Champion is coming to our track to work on his car setup... he is bound the take the record to a whole new level, one I daresay will take a long time to crack :bunny:;)
Can't wait to see you out there Glen, you will thoroughly enjoy it :(
Its about to be taken out of reach of me altogether. The multi winning NSW Champion is coming to our track to work on his car setup... he is bound the take the record to a whole new level, one I daresay will take a long time to crack :/:)
Owwww, looks like things are going to get serious from here on!!! I'm sure you won't let him claim it easily though! :(
Can't wait to see you out there Glen, you will thoroughly enjoy it :/
Yes thank you Michele! I definitely gotta give it a go! The atmosphere there is so good! :)
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
