I picked up the latest edition of speed, in which they alude to the fact that the Top Secret neo GTRs are running 12000rpm redline. I havent got it with me, but the essential gist was that this should be acheiveble on any finely tuned rb26.
I take a fair bit of what I read in speed with a grain of salt, but this leads me to thinking...
what rev limiters are some of perth/WA's better/more developed nissan engines running? what, apart from a fairly short stroke, does it take to run really high RPM?
https://www.sau.com.au/forums/topic/31163-free-revving/
I think limiting factor become stuff like head flow and cam sizing. I know the cars (Jap Import) that they setup for highspeed runs make peak power at about 9000rpm, but they push them out further to make use of the gearing. In other cars like F1 etc they have much higher rev limits due to different head design.
https://www.sau.com.au/forums/topic/31163-free-revving/#findComment-630292
on a silly side note, the HKS gt-r spins to 11,000 and gtr-700 spins to a couple more from memory, but we're talking 1500hp cars here with a pair of 3037's..
so they have the turbo's to make use of the extra RPM..
there also very highly developed motors..
https://www.sau.com.au/forums/topic/31163-free-revving/#findComment-630357
I am under the impression that the RB26 is the only rb engine with solid lifters? The hydraulic setup of the others is much less suited for higher rpms as (valve float etc becomes an issue).
RB30 -> longer throw = higher peak piston velocities, which is one of the larger factors in determining maximum rpm (time for some forged internals!).
Reciprocating mass, oil spec and quality, cylinder clearances, component composition, etc will also all have influences on what rpm you can achieve reliably.
https://www.sau.com.au/forums/topic/31163-free-revving/#findComment-636560
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
