so my car is ready to burn a deeper hole in my pockets just wondering where to start,
already got fmic turbo back zorst ebc and pod filter.
also getting a turbo unsure on specs at the moment in the next few weeks.
would it be best to leave the turbo off untill i get injectors, afm and fuel pump?
can i put the turbo on get an ecu and get it tuned to run safely on stock injectors etc?
thinking of going for a nistune, where abouts in adelaide is the best to get it done and tuned, is about 800 right for the unit installed and tuned?
\thanks
https://www.sau.com.au/forums/topic/311643-upgrading-32gtst/
ontop of what you already have, get a HKS 2530 turbo, a decent clutch, 555cc injectors, z32 afm, a bigger fuel pump and a tune and it should make 220-240rwkw
Again, Jeff will be able to give you some hints on what mods to do aswell.
thanks mate, how do i tell what clutch i have, its definately been replaced before i bought it but wasnt sure if it was heavy duty or a good brand
I got all of those mods and yet i get 205-210rwkw even after two tunes :) . One from Peter (Apparently a co-designer of the nistune software/hardware) wasnt happy then went to Morpowa.
just looking to purchase a fuel pump, looking at ebay and not sure which walbro pump is the best fit for a 32 gtst.
http://cgi.ebay.com.au/Walbro-255-In-Ta ... 45f181c8df
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0456368176
gss341 or gss 342
I got all of those mods and yet i get 205-210rwkw even after two tunes :P . One from Peter (Apparently a co-designer of the nistune software/hardware) wasnt happy then went to Morpowa.
Yeah Pete from PLMS is the co creator of nistune AFAIK.
You won't get 240rwkw from a GT2530 without cams and even then you would be looking at around 20psi to get there.
Yeah well I didnt follow through with it, decided to chuck a RB25 in, but thats only what I got told... I forgot they said I would need adjustable cam gears too. Also was told I'd be running 20psi.
Good luck in any case :cool:
Don't buy a Walbro from the internet, there are too many knock off pumps floating around and unless you get them from an authorised dealer like MTQ there is no guarantee that you will be getting a genuine pump.
thats never good, if i got a knock off pump would it end up doing damage to my car or simply not work, i wouldnt have a clue what to look for in a real one
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
