hay guys and gals
im about to do a rebuild on my engine and i am going the route of forged pistons i am thinking about going the rebuild kit that horsepowerinabox.com offers i just wanted to know 1 thing
it says u can get them in 3 different types
standard size (i obviously know what this on is lol)
20thou over
40thou over
now what i wanted to know was does going the larger size pistons increase the displacement of the engine??
i want to get around 380rwkw with this engine and a gt35r 0.84 that i have already
cheers
julz
https://www.sau.com.au/forums/topic/311673-pistons-question/
hay guys and gals
20thou over
40thou over
cheers
julz
Strip the engine first to determine what size you actually need, as it may already be 20 or 40 up. going from std to 40thou up is a negligible increase in capacity.
The increase in displacement is minimal, the overbore is more so for re machining of the block for when it is worn.
for reference 20 thou is half a MM
edit: beat me to it trent :laugh: must have posted at the exact same time
Hahaha if you're thinking it can be bored out to 2.8, sorry to be the bearer of bad news but that won't happen. I guess you could technically call an 88mm bore a 2.7L
use the 20thou, leaves you more rigidity and the ability of another rebuild in the future if anything bad was to happen
the engine will be stripped down as it is a lil tired and i ran it a lil low on oil by accident :blush:
so is 20thou bigger than 40thou ???
no 40 is bigger. It is best to go the smallest you can get away with as it allows another rebuild down the track (if something goes wrong) without getting custom pistons made.
Try spool imports man. They will supply you with the BULK of your needs.
I went the 40thou route, fully knowing if something happens, i will need a new block.
I doubt if you could test both sizes, you would actually notice a difference anyway.
Choose what you want. 20thou would be the safer route
If your wondering about the thickness of typical 05u blocks, the last block i sleeved broke through on a couple of cylinders when bored to 92mm to fit the sleeves. The sleeve design was made to suit a maximum piston size of 87.5mm, allowing for a 2mm cylinder wall thickness which Dartron (sleeve manufacturer) consider to be safe for this kind of sleeved block.
So what im saying is that if that same block had been used to run a 0.040" oversize piston the wall thickness at its thinnest point would have been just under 2mm. Thats not a lot considering the block is cast iron. Its no where near as strong as the spun cast sleeve material so that more or less explains why 87mm is considered maximum for most normal blocks.
Edited by GTRNUR
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
