Hello again peoples,
After saving a significant amount of cash for a Plazmaman FMIC kit, I have realised since getting my line back on the road that the part I'm least satisfied with is the suspension. I am now considering a set of Springs & Bilstein shocks especially now that I have stripped out the back half of the interior (which needs to be done to access the rear strut towers) to improve the ride & handing & maybe stop me hitting my head on the roof when I come across a bumpy road!
I have called Car Torque for a quote on the Bilsteins & some King springs, which all up came to $1290 (940 for shocks & 350 for the springs), which sounds reasonable for such a set up.
Does anyone recommend anywhere else I could get these parts? I did a search, but didn't turn up much.
Also would like to know if there is a suspension shop in Adelaide that people recommend (I don't know if people still recommend action suspension just going on previous threads), primarily if I bite the bullet & go get adjustable bushes as well. Going to need to find someone with a 10 tonne press before I get carried away there though.....
All comments welcome, cheers
https://www.sau.com.au/forums/topic/311756-suspension-retailers-serving/
adjustable bushes dont really give you that much in the way of adjustability. either get plain old urethane bushes (or if youre keen, delrin) or adjustable arms.
Edited by scandyflick
Car Torque is the place you want to go, they did my Bilsteins cheaper than the sydneykid price. They do all the whiteline stuff to.
Refer to my original post....
^^ is that north tce hackney
Sure is :banana:
Having done a bit more reading, I think I'm more likely to just go standard bushes for now if I get them, adjustable ones can also place un-natural loading on the arms potentially causing them to snap.
Definanately want to get the subframe alignment kit if I can for now.
don't forget to grab a front and rear sway bar if you can afford it. great bang for buck...
Yeah have been considering this too. Do want to experiment a bit & see how it feels just after a shock & spring change, but may do this also.
Prehaps I'll buy the lot & fit it in stages depending how hard it is....
Am also currently awaiting a call back from Manta about the shocks & springs. Will be interesting to see what price they give me.
Yeah doesn't hurt to shop around though. Have found out that Autosport Direct has got direct contacts with Gary (Aka Sydney Kid) & is also going to get me a price for the same package.
Manta called me back today just to let me know they were so busy they forgot to get me a quote Lol. Was nice of them to let me know just the same.
  • 3 weeks later...
Just an update on this.
I got a quote back from Manta, without actually stating the amount I will just say it was significantly more than Car Torque.
They also would have to be ordered/built first in Germany, no stock what so ever & at least a 6 week wait!
I will say they were the only ones who actually called me back though without me having to chase & they're not exactly short on business so it was nice of them to get back to me.
Also the lead with Autosport turned out to be a dead end, Gary (aka Sydneykid) doesn't supply these kits anymore period.
So Car Torque it is :cool:
Edited by J_Red33
Wasn't a coil over kit, nor that extreme in price, but were still talking hundreds of dollars extra. Just the standard Bilsteins with King springs same as what Car Torque was quoting on.
Nothing against Manta, they almost sounded like they knew it was a bit expensive, possibly because they would be a special order, where as Car Torque can get them from Sydney within a week.
Edited by J_Red33
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
