Still under 2k on the odometer. $70000 plus take over the lease @1500/Mth for 33wks with $80000 residual. Please PM me.
Is there actually such a thing as "taking over a lease"??
How much do you need to get for the car?
Im looking for a white R35 right now.
Kev
Does that work out at $162,000 for the car? think i got my sums right... :thumbsup:
Less than that in present value dollar terms. You need to take the interest thats factored into the payments into account. Deduct approx $4-5K.
And stamp duty is also dependent on the state you're in.
Edited by fungoolie
is everyones summs out of whack because I got a much higher value than $170k when you add in the risidual, i got just under 200K + stamp duty ect...
either way there are cars from $159000 drive away without negotiating and accept trade ins, only prob is they have double the milage (4000km instead of 2000).
http://www.carsales.com.au/all-cars/demo/d...2&silo=1011
Not sure how you arrived at that figure. Without stuffing around with net present value calculations all you do is add the first payment and residual so say $150K. Then add the $12000 worth of instalments. So even without the interest component being taken into consideration it's $162K plus ORC. As I said earlier, interest on the outstanding $80K over less than a year is less than $5K.
Edited by fungoolie
ahh I misread it, I read it as 1500/month for 33 months, instead of weeks.... I was wrong.
Still $180k for a car that didn't cost that much more to buy brand new in the colours and extras you want? Its way over priced dude. I know that Rick Damelian held his 2009 ADM GTR for 4 motnhs advertised @ $159 000 + transfers ect... It sat there for ages then they took $155 000 drive away transfers included.
If you need the money soon I think its best you get what you can for it now and cut your losses, expensive cars arn't selling too good these days.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
