For Sale:
1990 Nissan Skyline r32
118 000kms
Black
4 door
automatic
RB30DET engine built by qualified mechanic and ROTORBISHI owner/builder
Price: $9000.00 or swap for p plate legal cruiser motorbike plus cash my way.
TRB-001 plates included
October 2010 nsw rego
Sunroof
Brand new genuine air vents
Nice tinted windows
Genuine floor mats
Fully functioning A/C
Kenwood cd player
New wiper blades
New iridium spark plugs
Comes with lots of spares; stock wheels 2x new tyres, rb20 head, afm, strut brace and much more.
ENGINE:
Reconditioned RB25DET head with new seals, gaskets etc.
Tomei Metal Headgasket
RB20det intake cam with disabled VCT
Freshened up Series 3 VL 3L block
Standard Pistons and rods
New bearings, gaskets, seals throughout etc
New genuine nissan RB25DET oil pump
K/N panel air filter
Customer fabricated intake pipe from air box to turbo.
Fully functioning PCV and standard BOV for legality
All fluids flushed and replaced
New hoses, lines, belts, silicon joiners etc
Front mount intercooler
Serviced AC compressor
ECUTALK OBD 2 Display
TURBO:
ATR28 Hypergear turbo with .63 rear housing (very responsive)
3inch mandrel bent exhaust
FUEL:
Custom 1.5L surge tank mounted in boot
Bosch 044 inline fuel pump
standard rb25det injectors
Brakes:
new brake master cylinder
the usual 4 spot front and 2 spot brakes
new brembo pads all round
new flushes brake fluid
ECU:
Rb20det ecu with NISTUNE chip
Tuned by INSIGHT MOTORSPORT in west sydney
Dyno print out for 166rwkw and roughly 470nm of torque on standard 7psi with auto slipping
Tuned on 9psi and made 190rwkw but auto slips and doesnt shift smooth enough so we removed boost controller and tuned for 7psi
With manual conversion and tune on 9 or 10 psi will make 200+ rwkw, and with bigger injectors and tune will be around 250rwkw
Wheels:
18 inch HR RACING 5 spoke racing wheels
95% 235/40 r18
full set of lock nuts
Bad points:
small scratch on 1 wheel
passenger side door trim material has come off
switch for left rear window on drivers control broken
small mark on front pass seat
seat pocket has small rip in stitching
sunroof has been sealed shut
(all has been done by previous owner)
Overall car is very clean, engine conversion is very neat. During the build, alot has been done to minimise attention from the police.
I am very careful and everything has been done for a reason. I have receipts for some things.
I have been honest with the cars condition. Pictures dont do the car justice.
Im selling because I dont get the chance to drive the car very much as i have a company car and a motorbike.
Im after $9000 cash or swap for p plater cruiser motorbike plus cash my way.
pm me or sms/call steve on 0402852347
Edited by TRB-001
https://www.sau.com.au/forums/topic/311829-fs-r32-4-door-rb30det-syd/
Is the car engineered and registered with the RB30DET?
Does anyone know if one should expect much trouble from VicRoads bringing a car of this spec to Melbourne? Can you legally register an R32 with RB30DET in Victoria?
its not engineered yet, however i built it with the intention to engineer it so it should be pretty straight forward. Infact i may get it done if the buyer pays the original $9000
Edited by TRB-001
Just go to Vicroads, get a engine transfer form and state the new engine No. No certificate required
please note there is nothing actually wrong with the automatic transmission, it has been noted that it 'slips', it is only detectable on the dyno by looking at the numbers, to put it simply, a brand new gearbox behind this engine would do the same thing..... car is still for sale, i am neg on price, need to pay off the home loan.
actually you need engineets cert as the car never came with that specfic engine
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
