i have an emanage ultimate with direct plug and play loom (n4)
these looms are few and far between... no splicing and sus ecu wiring needed
timing control, fuel and air map control... boost is possable with the addition of a boost sensor ($120 or so)
SENT AUS WIDE $750
Msg me 0400099986 or PM thanx
https://www.sau.com.au/forums/topic/311906-greddy-emanage-ultimate-cheap-cheap/
hey mate, any chance of a pic on here???
if not can you send one to [email protected] please, also do you have wiring diagram for this item as i will be puting it in my vl with the rb25det conversion.
thanks
thanks
here ya go mate... its just a matter of getting the 2 big rectangle plugs... one goes to your ecu, the other goes to the plug currently pluged into yout ecu... the wiring diagram is on the greddy website and here... ill get onto it now for you tho...
what state you in??
Just doing some research on these units, to runtjis unit in a gtr you need to change 2 wires around and ground one. I've got the diagram
Hey mate, what exactly needs to be done to fit this to a GTR?
I thought the N4 loom fits GTR?
Cheers
  • 2 months later...
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
