Mostly happens when there's a very sharp dip in the road, pot hole, whatever. Also happens when turning sharply on a bumpy road. (It does it on some corners of Old Pacific Highway) ... is that metal bit above my tyre supposed to be sticking out that far?
The tyre size's I have is 235/45R17 on 17" Work rims. Standard suspension (I think) ... it's not low at all.
Edited by RB25PWR
https://www.sau.com.au/forums/topic/311910-is-this-normal/
ummm, correct me on this but i tawt that upper arm moves with the suspension so doesnt matter which way it travels u always have the same gap. jus checked my car, the gap seems similar so id say its normal, u may have wheel rubbing sum where else. best way to confirm this is take wheel off and look under suspect area, u will have a definite rub area thats free from dirt and stuff. if not there look for same symtoms in other areas.
https://www.sau.com.au/forums/topic/311910-is-this-normal/#findComment-5134445
I think it might be a problem as i have 235/45 R17's on at the moment (i have not noticed that it rubs on that bushing nor does it feel worn) and also the sticker inside on the drivers side door gives the Kpa measurement if your using this size 235/45 R17. The car should fit the tyres no problem at all.
Also your bush looks very close too your tyre there, mine was about 5cm's apart.
https://www.sau.com.au/forums/topic/311910-is-this-normal/#findComment-5134621
i have 235/45 and looks very similar to yours but im pretty shore im not getting any rubbing but probs will be getting 235/40 next time around
u should take the wheel off and have a good look also full lock the steering both ways with the wheel on
https://www.sau.com.au/forums/topic/311910-is-this-normal/#findComment-5134955
It doesn't rub on it per say. It feels like it hits it very shunt-like... I only really notice it when I'm going down a hill, and right at the bottom of a hill there's like a TINY dip in the the road.
Poor illustration but you get the idea. I gotta admit I don't know whether it's hitting that thing for sure either, but wtf else is it hitting?! =\
https://www.sau.com.au/forums/topic/311910-is-this-normal/#findComment-5136359
the top of the shock is hitting the bump stops. Or if you've cut the bump stops the top of the wheel is hitting the top of the wheel well. Look up my son, look up.
In the first pic, see the spring - then inside that is the bump stop. The top of the shock body is hitting up against that. Have you got stock shock absorbers and springs?
Or more likely you have lowered springs and stock shock absorbers. Probably could do with some new shock absorbers. and if you've got lowered springs I'd take about 10mm off the bump stops (cut them).
https://www.sau.com.au/forums/topic/311910-is-this-normal/#findComment-5137669
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
