  • 1 month later...
i've got one sourced thats had the wires and loom cut from compliance.. but the guy assures me u just solder them back together and everything is all fine cos thats what he did with the other one in the pair. worked fine apparently!
anyone done this before? :)
Hey bud the person you have sourced them through is me lol... Anywho ill send through my details asap!
Edited by Ceffy_SA
No probs, in regard to the new globes you need just get these like i did, cheap as and work really well, order the 55w versions too their not to bright, i just went the 6000k type.
http://cgi.ebay.com.au/D2S-D2R-Xenon-HID-4...=item45f289d2c7
i have tried 6000 and 8000. i prefer the 8000 as the 6000 are brighter and whiter, and the 8000 were bluer and less nasty on the eyes! :)
why all of a sudden 30$???? lol i bought them 6 months ago for $60!!!! bastards! haha
will have to buy some while they're cheap! :D
i've installed the new ballast, but my globes are waiting to arrive (and i didn't want to test it with my sole working globe :P )
turns out you have to cut the ballast out, and solder a new one in (its not just a swap out job like i thought)
as the plug on the end of the loom will not fit back through the hole without having to "un-glue" your headlight.
big props for Scottynm35 for giving me a hand! i owe u one two dude! :P
got my new globes today.. put one in, and nothing.. :)
might have to replace the whole headlight.. :P
Mmm, sorry to hear mate, at least it didn't cost you too much to try and fix it. How much is a headlight going to cost?
i'm thinking i'll go with an aftermarket D2R HID kit now. ($130 + install) pretty sure i'll be fine!
better than driving around all lop-sided without one headlight!
pretty sure if they see my engine bay, they aren't gonna say anything about the headlights cos they'll be too busy looking at the other toys :) hahaha
Edited by atomaly
i also heard that it "sometimes" makes a difference if the green wires are soldered the wrong way around on the ballast?? due to polarity or something.
bad news is, my other headlight is flickering now...... :P i'm thinking this D2R aftermarket kit is looking better and better
okay, took it to auto electrician,
my newly installed ballast DOES work :bunny: it blew a fuse somehow when i was installing it.... only problem now is my other one is on the blink .. :| comes on then turns off after a short while....will try swapping the globes around...!
i know :) very happy that it was just a fuse!
and i bought a pair off ebay, but they sent 1x8000K and 1x10,000K. i was dumbfounded..
so they're sending me another 8000K so they match what i requested (somewhere between China and Aus atm)
so that gives me a non matching spare. :blink: haha better than no headlight
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
