http://forums.skylinesdownunder.co.nz/show...&threadid=29881
Interesting to see you read the same post Merli. Hehehe
So did you pay $1800 for it Mirkop and now trying to make the big profit or was the $1800 post just full of :bs!:
Cheers
Ken
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-630718
well if you people havnt realised there isnt just one type of OS giken clutch, the are 3 types. and all 3 have differnt power ratings. i can still get anyone on this website a new os giken twin plate for $1800 if they like a power rating of only 300 horses. where as this one has a power raing of over 700. so maybe BIGBLOCKR31COUPE and gtrken should get their facts right befor posting. it would just ake you look a little smarter, if that is possible...
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631157
You're right. There are three types of twin plate OS Giken clutches.
TS2B - Pressed Steel Cover, Twin Plate, 204mm Clutch Plate Diameter.
TS2BD - Pressed Steel Cover, Twin Plate, 204mm Clutch Plate Diameter, Sprung Center.
TS2CD - Pressed Steel Cover, Twin Plate, 215mm Clutch Plate Diameter, Sprung Center.
Japanese Retail Prices are as follows:
TS2B - 143,000 Yen
TS2BD - 148,000 Yen
TS2CD - 158,000 Yen
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631260
TS2B - 143,000 Yen
TS2BD - 148,000 Yen
TS2CD - 158,000 Yen
So what your saying merli is the cheap one that Mirkop is talking about is
143,000 yen which is about $1800 and the one he has for sale is the
158,000 yen one which is about $2025?
Or am I just stupid like Mirkop suggests...??
hehe
Cheers
Ken
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631368
hehe
Cheers
Ken
I'm glad someone was able to draw the obvious conclusion that I was hinting at bigthumb.gif
There ain't $1200 difference between the three different OS Giken twin plates mikrop.
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631475
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
