Hello,
I just installed a HDI electronic boost controller for my r32 GTST but am having issues with it.
When on boost (5k rpm) the car will cut out and make loud sounds from the exhaust. (misfire?)
The EBC was installed by an auto electrician so hopefully we can eliminate a wiring issue.
Before I installed the EBC the car was fine, boosting to correct levels.
I've attempted to change the setup back to normal. Leaving the EBC in the car but bypassing the EBC solenoid which initially fixed the problems but since has stopped working properly.
What could the issue be? Spark plugs?
I've searched the forums but can't find a matching issue to mine.
(brb flame proof suit)
https://www.sau.com.au/forums/topic/312355-ebc-boost-issues/
you havnt mentioned how much boost you were/are running.
do you have a boost gauge?
are you sure theres no adjustments on the EBC?
and that it makes exactly actuator pressure before it bleeds any air off?
my moneys on its making more boost and your going R&R or too lean @ 5k rpm
also just one of those misfires etc when you first had the EBC on, would've fouled your spark plugs, now they are struggling to fire.
so new plugs as Nismoid said, then see how ya go...
yeh thats what i was thinking, with the fouled plugs. well now it should be running stock boost cos i set it up bypassing the ebc's solenoid, when i had the ebc on the boost kept going up rapidly even tho it was on the lowest setting, it hit 14 at one stage
I also have a HDI EBC-R, i havn't had an issue with it yet. As the guys have said, more boost requires more spark etc i would change plugs and if you can't afford new coils, get some industrial grade silicone and glue them up not a total fix but will fix most probs (unless coil completely gone). Also get out on a QUIET road or more safer a dyno and get it tuned and set right, if it's boosting to 14psi when it's not ment to check all hoses at the soleniod. This was happening to me but mine hit about 16psi (Shyte), i found that one of the hoses has a slight split. If you set boost to high you may break something. (BOOM) show me the money.
my two coin
Cam
thanks mate, yeh mine hit 16 psi yesterday after i thought id fixed it :blink: although it didnt feel like it was pushing 16 psi. i got some spark plugs will put them in on sunday. only want to run 10 or 11 psi at the moment too
my two coin
Cam
spark plugs fixed the misfire, but the boost controller just doesnt control the boost, it pushes past 16 psi!
runs fine if i use the same hoses but instead of going into the solenoid i just put them back into each other like an extended version of how they are normally set up, runs 11 - 12 psi though
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
