hi guys,
i did a search & couldnt find what i was looking for - as of yesterday my knock has increased as i noticed this in 3rd gear when i got to 6500rpm @ 24psi, read 70+.
when i reduce the boost level to approx 20psi the knock drops to 40 (as per pfc) & even lower boost showed 25knock.
my tuner will check this out for me but in the meantime i would like to do a check over so i dont waste his time...paul (mr swiper) was suggested i blow out the loom connectors with an air compressor as water may have entered the connectors when i washed the engine bay last week & also to check that the spark plugs all look the same (maybe a plug has failed?)
is there anything else i should check OR has anyone else experienced high knock due to something rattling/loose in the engine bay? i dont want to feel like a d1ck with my tuner if something else is causing this bizarre reading...
thanks.
marko
https://www.sau.com.au/forums/topic/312402-knock-level-increasehmmm/
  • Replies 66
Possible that you have picked up a bad batch of fuel. If nothing else has changed its weird that it will suddenly change.
I would have it looked at asap.
this is what i 1st thought - i ran the car basically dry then refilled at another bp servo (98 ultimate) & same thing.
It'll probably just be a cell that is slightly in need of attention.
Nothing major
yeah i had a squize at your pfc faq...you are probably right.
i have dropped the boost level anyway, better to be safe than sorry
Nothing major
+1
Yes indeedy, i had a knock reading of 120 randomly one day doing about 200kph, this was after consistantly never reading over 20 so probs like R31Nismoid said just a cell need a little love :P
Cheers,
Mitch.
or coils if the tune is good
If it were coils I would probably feel the loss in power in higher revs? Although this also crossed my mind
Would a faulty coil cause this symptom, I don't think so as the symptom would be hesitation
I will pull out the plugs tonight and if they look the same then off I go to my tuner
there wouldnt be any loss of power i would think it may just have a little unoticable missfire that would show up as knock. Happened to me.
But to be honest it sounds like your tune as your knock levels went down when you put loss power down.
tuned in summer? temps dropped up there recently? cold night maybe... other than that its probably as Ash suggested if you have already ruled out fuel
It was tuned on a 33deg day, the problem appeared on a 18deg day...could a drop in temp cause it?
Yes, most certainly.
As everyone has said, more than likely just a cell or two that need minor attention.
I think you need to buy a stress ball or something, a minor one-off knock is hardly anything to get excited about. :blush:
Take it back to the tuner, get it fixed. Should take less than 30mins. Drive it sensibly until then... easy as pie!
u might be right here - ji ust pulled out the plugs & no.4 plug is a lot blacker than the others...when i look at the coil pack for this plug it seems that the black lead tip on it is shorter than the others
paul - you are a legend mate, i think once again u are right - you freak!
i spoke jim @ crd & he explained that the coil pack was mis-firing with the pitted coil pack lead tip which is why the plug was black & this causes all sorts of things i.e. spark over which makes noise, even possible pinging.
i haven't test driven it yet but i'd say it is fixed :D im almost ready to put my head on the chopping block if its not rectified
i will report here once ive take it for a wrap on a long straight, 3rd gear under load
worse case i may need to buy a set of splitfire coilpacks
:D
  • 3 weeks later...
hi guys,
last night i took my car for a drive with new my splitfire coil packs & it is still knocking high so ive left a msg for my tuner to look at my car. i was hoping the coil packs would have solved it but anyway...the joy of modded cars!
2nd gear showed 34 peak knock, 3rd gear showed 66 peak knock.
i then cruised below 3krpm in 4th gear @ 60kmh - when i reset the peak knock on my pfc hand controller it immediately shows above 20 peak knock & as high as 25 peak knock (i did this back2back test a no. of times & got the same result every time). HOW is this possible on such low revs??? i think my knock sensors are not reading correctly, either they may might need replacing as ive been told they can fail OR maybe 1 of them has become lose over time, i luv playing the guessing game (reminds me of an ex-girlfriend)
if the problem was just a cell that needs attention as suggested in my above posts, would i still have the same results considering the circumstances i.e. low revs, high knock?
20 on the knock is no issue. Just driving around mine i think sits around 10-20.
There is always going to be some noise picked up, the fuel is combusting after all.
You only really need to worry about knock when it gets over 30-35. Anything below that is largely irrelevant.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
