sorry guys dont know what happend there with it coming up 3 times, also does any1 have a pic of the back of an R34 clutch pedal?? mine fits in fine i just dont like the way it attaches to the firewall, looks loke its ment to have another piece in it to sit against the firewall better, ill take some pics of mine and post them when i get a chance
The manual conversion thread is HERE, and I myself have posted quite a few photos of the handbrake location in there somewhere...
Sorry, can't help with the question on the pedals, though.
:blush:
Do you know what hand brake you have got
The skyline ones are very similar to the stagea one, but the mounting feet are different angles
I used a brand new stagea one for ease, was aprrox $170 and was not worn out.
To make things easy you need to use the mounting bracket that is normally welded in on the tunnel.
The bracket is made of 2 peices spot welded together. Series 2 auto's have one part of this bracket already so you only use one half of the new bracket. Series 1's I believe need to use the whole bracket. Either weld or bolt to the floor. Then the hand bracket will sit at the correct angle and line up with the centre console.
Same with the clutch pedal, the stagea and r34 are the same, but the mounting bracket to the fire wall is different. Grab a stagea one and you will be right
Have you got a centre console yet? I might be getting a spare one and possibly the pedal brackets etc. :blush:
Attached is a couple pic's of a full stagea manual conversion. Might help
My conversion is from an RB33 GTR so maybe that makes the pedals easier to fit. If you look at the handbrake you will see that it is bolted on to a black plate. The plate looks as though it is rivetted on but is in fact welded to the tunnel.post-49463-1269220784_thumb.jpgpost-49463-1269220856_thumb.jpg
i dont know what handbrake they gave me but it was the wrong one, it had R33 in texta on it by mistake, all good now and have the right one, where do i get that bracket from?? do i realy need it?? has any1 else made there own brackets??? or is it a cheap part to get??? all the frontcuts i looked at today had been cut just after the gearstick hole
You can buy all the brackets from nissan. approx $70 for the handbrake one
Much easier to use the factory bracket so that you do not rip out of the car over time when pulling the brake on
ill go into nissan tommorow and see what they can do for me.. that part number on the bracket is that a stagea one or an R34 one??
also is this diagram right?? it just seems strange that there isnt anything siting flat on the fire wall instead of the circular points around the bolts being the only thing in contact with the fire wall,
The bracket is out of a series 2 manual stagea, not r34
That is right for the bracket onto the fire wall, that it fits thru the sound proofing.. There is also some other mounting points which fix to the dash cross brace
and u got that bracket localy???
mmm, i cant wait 3 weeks for that.... i might have to make up a temp one, did you weld yours to the tunnel or are they riveted on like in that other guys pic??
Used 4-off 6mm bolts with lock nuts in the tunnel
I drilled the spotwelds out of an R33 to remove the handbrake bracket. Worked great along with the handbrake itself and the clutch pedal/master cylinder.
i might see if ican find a 33 at the local pick apart then cause the import ones didnt have what i wanted.. also what clutch is every1 using?? my mates gunna order me an exedy clutch, do i just get one to suit an R34 or does the r34 use a pull type clutch?? im using a 32 gearbox so its a push type...
R34 GTT uses a pull type, unsure of R34 GTR. Most R32 GTR's are the push type but as darrinspencer will confirm, the later model ones are a pull type.
Edited by QWK32
Josh is right
All Rb flywheels are the same
I use a late model R32 gtr box which is pull type rebuilt by Jim Berry for approx 300rwkw cost around $900.
Looking at upgrading when the new engine goes in as it slips already esp being AWD
Push type clutches are cheaper
Josh is right
All rb flywheels rnt the same, I just compared the one I was given being told it was an r34 flywheel.. To my r32 gtr flywheel I had and they are difrtrnt.. So confused what to do now... Gtr or r34 flywheel... The guy at exedy said gtr push type kit.. Mote feedback from other guys please
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
