Ok guys, please take it easy on this one, I'm new to all this :blush:
I've had a pretty long look through the forums and there seemed to be a lot of dispute when it comes to spark plugs. I've got a stock r34 gtt with cat-back exhaust, what should I be using? I'm not sure what's in there not cos i haven't looked since i bought it (only just read how to), so I'll be having a look this week. There is a miss-fire at idle tho.
So what's the deal? Copper, platinum or iridium? They last different amount of time, right? I'm trying to learn as much as i can at the moment so i don't mind changing the plugs every 5000km with oil (also changing that this week cos, its been almost 7000km and starting to hear a bit of ticking, hoping the change will fix it).
I understand is like this: a certain voltage is sent through the plug, which causes the spark, so smaller gap means the spark happens earlier in the piston cycle (as well as being more consistent as less spark is required). Copper requires less voltage to cause the spark (ie more consistent between cycles?), but due to the properties of copper some of the spark plug is lost during each spark. Platinum and iridium are much harder and thus so they don't erode as quickly. The erosion affects when in the cycle the spark fires because it changes the plug gap.
So, please correct me if this is wrong!! And what do i buy? lol
Thanks in advance
https://www.sau.com.au/forums/topic/312824-another-spark-plug-question/
if ur happy to changing the sparkplugs with oil change then copper plugs are the way to go.
iridium is over kill
and i have found that platinum dont always last 100,000km. i have had some go at 10,000km so im not happy with them but other ppl have reported success.
if u get misfiring at the top end then its because the gap is 2 big or the coils are arcing out. to fix = new coils, close down the gap, silicon the coil mounting bracket.
i have not had misfiring at idle so im not to shore maybe change the oil, sparkplugs and see how that goes.
i personally dont gap my sparkplugs i should to make shore there the same but so far i haven't had any problems other then platinum sparkplugs that shit themselves after 10,000km and some arcing
the part number 4 my copper plugs BKR5E-11
follow this link to understand the part number http://www.ngkspark.com.au/sparkplug.php#
thanks mate. when i posted this i'd only searched the gen maintenance forums, but there's a massive amount of confusing info in the faq sticky in the forced induction performance forums.
hoping it sounds happier after this weeks service, it'll be good to not fear the old oil hurting the engine
don't run the BKR5 plugs on a turbo car. they are too hot and may cause the car to ping, which leads to other bad things. BCPR6ES or BKR6E are the plugs to run. the BCPR6ES plugs are actually a slightly taller plug so will make contact with the coil a bit better, but either will do. those plugs are gapped at 0.8mm, for the ones with the 1.1mm gap (which is stock but may result in a missfire with weak coils) then add -11 to the part number.
as for how often to change them, i pulled my BCPR6ES plugs out after 5000kms and they still looked fine, and were still performing fine even on 14psi, so i could've got another 5000kms out of them easily. the plugs i pulled out before putting the copper plugs in were iridiums that were only 20,000kms and were stuffed, so at 5 or 6 times the price they certainly weren't worth the extra money.
This
For a stockish datsun ;) just chuck in some bcpr6es plugs, clean them, but replace them every 2nd or so service.
At stock boost, I wouldn't be able to justify going iridiums
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
