studio + lights + someone that understand image composition, exposure and how to use lighting effectively = great photos
Fixed :P
As someone who owns a lot of DSLR gear, I can assure you that gear does not guarantee a good photo :P
I'll see if I can remember to get some measurements of them if you'd like?
meh, it'll probably end up in the too hard basket, not enough m35 parts like that floating around down here plus i'd need to remove my washers etc, etc
Pretty sure Ian has some spare's!
what you should be doing is buying an M35. not just the washers :thumbsup:
Yeh I hear there's a Black AR-X for sale with 268AWKW's on BP for sale atm for about 12K! :P....fastest one in Oz I hear too!!!
Edited by Jetwreck
your selling?
why?
fastest, my ass!
maybe!ph34r.gif....wife wont take it as her car so I can buy a new one!.......so she get's to keep the shitty old Bluebird and I'll still buy a new car for me!
Do you know of a faster one.....cannot be your's as you can only do 171.5km/h!!! :P....oh and you cannot go around corners or stop!
Edited by Jetwreck
yeh but atleast i can change gears.
as if you sell it? TRAITOR!
Oh.....that's also means that NSW's has the fastest M35! :P....and just remember I have a lot HP that I can still make once the boost is wound up past 15psi....and for shit's and kick's an E85 tune!
Just need to get off my arse and put the shift kit in the new gearbox! :(
Edited by Jetwreck
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
