Hiya guys i got a bit of a problem....
When i turn on my car or if my cars on and i turn on my climate control, there is a slight knocking sound coming from behind the unit inside the dash. This lasts maybe 10-15 seconds but everything seems to be working fine!!
Any1 else had this problem or know what it might be?
Cheers
had the same sound as well. i suspect that it could be the internal vent opening up to allow air in. i usually circulate the air inside the car when the A/C is on but when i turn it off, i noticed wind still blowing in when the car is moving and i realised that the vent has opened up to allow gushing air.
may or may not be...
yeah, there are two relays (motors) which slide open the vents in the heater unit to control between the aircon and heater to give your xx degrees. If one is slightly dodgy, it may make that ticking noise - its like "slipping" on its catch.
Its no biggy, most skylines seem to do it to some extent. It doesn't worry me..
see this:
http://www.skylinesaustralia.com/forums/at...tachmentid=9971
This is the problem.. that black thing ontop is one of the relays (there is another on the side of that box) that slides back and forward to open the vents in there. If its slightly stuffed it will "click" when operating.
I have this problem too! i fkn hate it. first i tried punching the **** outa the dash, obviously didnt work. What is the parts name that i need to replace??????????????????/
im fkn sick of it, if any1 knows, tell me so i can replace it. or if any1 has it. URGENT, AS I NEED TO SELL MY CAR AND CANT!!
THANKS
you could buy my heater box for $40.. it has the relays on it. Then you'll have to pay somebody to pull apart your entire dash to the firewall (or do it yourself) and replace these components, which is about a 6 hour job.
you still want to fix it?
Hello predetor. Yes i do wona fix, i fkn hate that sound and sick of punching the **** out of the dash hoping it stops. OK so you have this part called the 'heater box', if you are mega positive that the noise will stop, then yes I will definetly buy it. How big is the part and how much is shipping, as I am located in melbourne, I am going to get it installed for free from my mechanic, so not a problem.
I got the same prob too...
The way I stop it (temporarily) is push the ^ button once (to turn temp up) then the v button a few times (to turn temp down)
you can do this with the unit on or off doesn't matter, and it stops it for a little while...
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
