Hi ABuSD, R33 RB25DET uses side feed, high impedance injectors @ 340cc and that's enough for around 340 BHP, 253 kw, 190 rwkw or 255 rwhp. Do a search and you will find heaps of posts on this subject.
I have a RB25 power fc, high flow turbo, front mount, malpassi reg, exhaust, dump pipe with standard injectors my car made 229.2 kws at wheels @1 bar boost with fuel pressure @ 90 psi @ 1 bar boost my air flow ratios were 11.5. Couldnt tune for more boost because no. 3 coil pack was breaking down.
Michael...
Ok GTS-t VSPEC, here we go again.
"It has alot of do with engine management"
Explain this to me, if I have an engine that shows an A/F ratio of 12 to 1 at 6,000 rpm at 1 bar using X brand ECU. How will it make any difference to the amount of fuel used if I have Y Brand ECU on that same engine that shows an A/F ratio of 12 to 1 at 6,000 rpm at 1 bar?
Same rpm, same boost, same engine, same injectors, same everything, how can one ECU use less fuel over another ECU if they both produce the same A/F ratio?
Now if you can't get the same A/F ratio with Y brand ECU because it has limitations, then that's a different story. But the A/F ratio won't be 12 to 1 and the dyno lambda sensor will show that.
I had a very long conversation (cost me many beers) with a couple of Motec and Autronic engineers at Bathurst and this was one of the subjects. As long as your A/F readings are consistent (they don't have to be correct, just consistent) then there is no way they could see where one ECU would use less fuel than another.
Maybe I've missed something, I am here to learn........
  • Like 1
I had my standard R33 series 1 injectors flowtested and they all flowed between 500 and 550cc? Or are you just saying that with the standard regulator they will only flow 340cc?
Also - I think GTST-VSPEC was just alluding to the fact that different tuners and different engine management can produce very different results. The engine management is like any other piece of equipment - it's only as good as the operator.
Hi caminperth, at 38 psi the R33 GTST RB25DET injectors are rated at 340 cc's per minute. I have cleaned and tested over 20 sets and they have all actually flow around 350 to 365 cc's at 38 psi. This is normal tolerance. If you increase the fuel pressure they will flow more, but at 38 psi they should only flow to their rating.
So if your injectors flowed between 500 and 550 cc's, then I would say they are either not standard R33 GTST RB25DET injectors or the fuel pressure was a lot higher than 38 psi.
In addition a 50 cc variation (from 500 to 550) is far greater than I have even seen, and would result in the cylinder with the 550 cc injector running 10% richer (and that's a lot) than the cylinder with 500 cc injector. The most I tolerate is 3% and I carefully select which cylinder each injector goes in ie; I put the highest flowing injector in #6.
Hope that clarifies
and when will i have to upgrade my fuel pump, is it when ive got over 240+rwkw??
On an R33 GTS-t i'd be doing this around 180-190rwkw. The standard R33 GTS-t pump is rated at 300bhp which is approx 180rwkw.
400rwhp = roughly 308rwkws'
400 x 0.746 = 298.4rwkw
But lets not get down to the nitty gritty :P
Is an aftermarket ECU "required" in order to use aftermarket Injectors? (ie; 550cc's instead of the standard 340cc's). Or will the standard ECU just continue on its way and pump more fuel in "if possible" ?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
