I can tell which one not to go for, and that's the BLitz kit. If it's the one I'm thinking of with the (IMO) ugly-ass arch extensions I can think of nothing worse to do to a GTR.
I agree with sewid though, the GTR looks pretty damned awesome from factory but if I was gonna put a kit on it, Top Secret would be my first choice! ;)
My friends Top Secret R34 GTR:
is nothing short of perfect!
and for comparison purposes:
In the forground, my R34 GT-V, middle is the top secret kitted GTR (above) are then a standard R34 V Spec.
Dave
https://www.sau.com.au/forums/topic/31416-r34-kit-need-help/#findComment-634415
