My air con struggles to get the car cold when the temp hits the mid 30's or so. Like if it's a hot day and the car is in the sun, it'll take forever to get the car cool. Well, maybe 15 minutes or more? I've never timed it although I probably should. But when the temperature isn't as severe, the air coming out is pretty cool and it doesn't take long to cool the car down.
I've spoken to a few people and they seem to think that this isn't right and that the air conditioning needs a re-gas. I know it's not fully out of gas by a long shot, but I'm basically just wondering if it does really need a re-gas, or if it's just that the modern refrigerant is inferior to the old CFC stuff and taking a very long time to cool the car down on a hot day is normal and acceptable?
I've also heard that they generally need re-gassing every couple of years regardless. If so I'd say it's overdue anyway.
https://www.sau.com.au/forums/topic/31420-air-conditioning-re-gas/
I have just had my aircon regassed and the air coming out of the vents is at -3 degrees C.
It still takes a while to cool the car down on a really hot day. If the car has been in the sun and the interior is all hot then it can take 5 - 10 minutes before its down to cool (about 25 degrees).
Get a temp probe and stick it a fair way into the centre vent. Run the aircon on 18 degrees (or F/C) with full fan in the shade. What does your temp probe say?
I'll check it tonight with my digital thermometer, but I'm 99% sure it's well above -3 degrees. I set it to 18 degrees to check yesterday and it was cool but not cold to touch.
I'm sure it would still normally take several minutes to cool down if the car had been sitting in the sun. But I went up the coast over Christmas, and after stopping at a servo for less than 5 minutes in a cool car the aircon had to work its arse off for at *least* 15 minutes to get it cool again, probably more.
I'll check the temps but I'm pretty sure it needs re-gassing if yours is -3. Man, -3 is colder than my freezer! (which also needs a re-gas)
regas.. yeah, the air gets warmer and warmer until eventually its not cold at all. I've had it happen on an old car.
Apparently there is a gas u can use which is compatible with the system and also "ozone friendly" or whatever. It was covered in a previous thread. Couple of hundred bucks i think.
did you chk the little glass hole thingy on the compressor?  its supposed to tell you whether you are outa gas anot i thk....
thats right, but how do you inspect it? how do u know by looking at it if there is gas? i was just wondering about this yesterday :headspin:
something to do with the colour i thk but the theory works for all compressor. run a search on the net or ask your local aircon mechanic.
in the meantime, i will be doing a search myself. my a/c is working fine but its better to be safe and sorry.
ok... here's wat i found... dun quote me on it though
http://www.bba-reman.com/aircon.htm
and taken from another forum
The little glass topped device just in front of the radiator on the passenger side is the refrigerant flow indicator. If the system is up to pressure you should only see bubbles flow passed window when the compressor cuts in and out and then it should only be for a second or so. If the system is low on pressure the refrigerant will stay as a liquid, the compressor should take it over the threshold to a gas.
Here endeth the first lesson. :P
hope this helps
The sight glass doesnt really tell you anything with R134A, as it did with R12.
With the air con running, check the temp of the pipe running through the firewall, it should be around 0 degrees. Vent temps should be around 3-5 degrees. Does the compressor cycle in and out, or does it stay off for long periods?
hey siksII,
where do you get those regas' done as they seem well priced. i've had quotes closer to $200
I got quoted $99 from my local mechanic :) BG Automotive in Meadowbank if anyone's interested. They don't specialise in Skylines, but they do know imports pretty well all things considered. These are the guys that repaired my rear-end accident from one and a half years ago, and they had no problems sourcing all the parts needed.
yeah 15 degrees must suck.. i used mine all weekend (1000kms) and it was working beautifully :(
My dad got quoted from a place that he was sent to by our mechanic, the mechanic is Lambs rd auto repairs in artarmon... so if you call them you could get a good price in case you live in the north.
Crazy. 15 degrees! I cleaned the in cabin temp sensor on saturday and reconnected the air-hose to the dash fascia (the hose connects to the small vent which is just left of the steering column on the dash, the temp sensor lives inside this vent) and the air-con is working even better/colder now. The air coming out of it is so f'ing cold i have to face it away from me or ill get frost bite.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
