hahahah
yep sounds fine to me :P
do you drive a lot? regularly fill up once a week? or do you rarely actually fill it, just put in a bit every now and then?
the fuel guage can be a bit finicky if you don't fill it often. Don't know why, maybe something dries out and doesn't work as it should. But i reckon just keep the car topped up for a few weeks and see how you go, guage might come back to life.
hahahah
yep sounds fine to me :cool:
Hey guys,
What i meant was...
Before I filled up my car with petrol, my gauge was sitting on Empty, with the petrol light on.
I filled up my car with petty and to my amazement It only took 52 ltrs of petrol..
Could this mean that I had 8 ltrs still in there or is the tank a 50 ltr tank?
Cheers,
Nick
Hey bud,
Did you go to top up at the bowser as soon as the yellow/amber fuel light came on? If so that could explain why it only took 52 L in, i've managed to squeeze around 100 kms on empy before chickening out to go fill up
Spec sheets indicate that R34 25GT and GT-t variants have a 65 L capacity
http://www.northshoreprestige.com.au/vehic...=r3425gtt#specs
hope that helps
Hey bud,
hope that helps
brilliant,
Cheers for you help! Good to know that I dont need to worry about the yellow light.. well not for a while anyways :D
Cheers,
Nick
spec sheets say that it is a 65 l tank but i have never filled more than 59l this one time i literally ran out of petrol as i rolled down a hill to a servo and it was dead and empt and it only took 59l
talking about close call !
Agreed, i have always suspected that it was a 60L tank rather than a 65L one,
However, referring to running on the empty light, having an after market fuel pump such as a Bosch 044 or 040 system will dramatically decrease the reliability of running the tank's ability completely empty so bear that in mind when your fuel light comes on
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
