hey guys not sure if this is the right place to post this but i have recently picked up my R34 GTT with very minor modifications to the engine and for some reason for the past 3 days in a row as i am driving or stopped at traffic lights it has seems to stall...
at first i thought typical RB (random bullshit) ;)
but now im not sure. i know the batt is on its way out but i didnt think that could make it do this??
it on has a KN air filter on it and thats about it...
any help or ideas or if this has happen to anyone else please let me know.
thanks heaps in advance for any advice :)
https://www.sau.com.au/forums/topic/314481-help-with-r34/
Do you have an aftermarket atmospheric blow off valve? Put the stock one back on and your problem is fixed.
Or try cleaning the AAC(Auxiliary Air Control) valve... it bypasses some air through when your foot is off the throttle.
And maybe clean your air flow meter with some electrical contact cleaner.
There is a tutorial on how to clean the AAC valve in the DIY section of the forum, just search.
Edited by SKYRYAN
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5159213
How do you know the battery is on it's way out? Could be the alternator...
Could also be a bad earth..
My stag was having trouble starting in the mornings and would randomly cut out or stall at lights, thought the alternator was dying.. turned out it was one of the earth leads back to the battery, the wingnut that was holding it onto the clamp was loose :D
Edited by bubba
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5160944
My stag was having trouble starting in the mornings and would randomly cut out or stall at lights, thought the alternator was dying.. turned out it was one of the earth leads back to the battery, the wingnut that was holding it onto the clamp was loose :(
Very true.
If the battery is dying that could well be a symptom. Check the battery and alternator with a multimeter, make sure you aren't missing any volts between the alternator and the battery. If there are more volts at the alternator then there are at the battery, check your earth and positive wiring, could be a bad connection or corrosion.
Alternator should be producing 14.2v while charging
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5160976
^^^ thanks for your thoughts, my fiance got home last night and the batt terminal for the power was corroded, so he cleaned it up and it found to be loose so that would explain things. it hasnt missed a beat today which is great :(
as for the wheels they came with the car, dont worry in the future there will be some jap rims on there :D
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5161274
well here is an update. it was fine for nearly 2 days because he cleaned the terminals and tightly sercured the terminal as it was a little loose after getting rid of the corrosion and then last night as we were going for a drive it happened AGAIN :(
we were travelling at 60 in 5th in a residential area and then all of a sudden the car lost a little bit of power and the slip light came on.... but it was only that light!! it was weird cause we have already been driving for at least 1 or 2 hours...
any light in this would be great, now i know the batt is still not the best but thats getting replaced next week.
thanks guys :P
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5163318
Take it to a specialist garage. If the slip light is coming on but you aren't breaking any traction then you could have error codes. They can run a scan for you and find out.
Oh and at least put stock GT-T wheels on instead of those massive heavy abortion bling things hanging off your nice car.
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5163437
stop hatin the chicks wheels. she might like them get the f**k over it! or do u need another beating at a set of lights?
Edited by dose_it
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5164629
Haha ooh big threat alert Ladies and Gentlemen! Because you driving someone elses built car is going to settle it? Or do you need a life rather than spending nights at traffic lights...?
Muppet.
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5164816
Muppet.
I'm a muppet am I? Who cares If someone built my car it's a cefiro good luck findin a stock one and I'd hardly call it built when it's got a 250 horse sr20 coilovers and a bodykit that just manages to chirp 3rd. Ha yep that's it I just spend hours cruising from lights to lights hoping to race standard skylines I was honestly to busy perving on ur ex missus.
But seriously who cares if she has chrome wheels. Ur the only person who can relate a stall problem to rims so maybe in reality your the muppet
https://www.sau.com.au/forums/topic/314481-help-with-r34/#findComment-5164852
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
