Set of four Starform wheels (these are a high quality jap copy of German BBS mesh style wheels) - see pic below.
Front 17x8", +40mm offset, 225/45 tyres
Rear 17x9", +45mm offset, 245/40 tyres
5 stud - the offsets suit R33, 200SX, 300ZX and Supra (I had them on my R33).
Excellent condition - minor kerb scrapes on a couple.
Asking $1,300 total including nuts & locknuts, but I would prefer Adelaide buyers who can inspect and collect in person.
https://www.sau.com.au/forums/topic/31468-fs-jap-17-wheels-tyres/
those tyres rock!!! they are the first set of tyres i've used that hook up even when taking off with a little grunt i had dunlop lemanz and could fry em at 60km easy but no chance with the contisports....perform very well in the wet as well!!! i might snap em up for the cressi if i get a little money left ova
1/ Do these rims fit on the front, without having to 'shave' ANY part of the front calipars?
2/ Would you consider these to be a lightweight rim, or are they at least lighter than the stockies? I have 19's but am starting to do some track work, and these are too heavy and tyres are too expensive to burn.
Al - To put them on the front of my R33, I used thin spacers to avoid having to shave anything off the calipers. I can provide these if required. The rims weigh about the same as stock 16" rims, but of course the 17" tyres would be a bit heavier. I can weigh the two together and get back to you if you want.
Matt - just got your PM - I will call you tomorrow.
  • 4 weeks later...
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
