actually never seen a R32 in Rocko
kewl stuff
there me burgandy R33 with bobtail wing.
3 other burgandy R33's
1 silver R33
2 possibly 3white R33's
1 two tone silver
1 two tone green/silver
1 R33 GTR black.
these i see regularly enough to believe they live in rocko :D
Got boost and kymbo
up for an informal chat 2nite?
Rocky forshore carpark (one with dolphin statues at the entrance) around 8ish?
https://www.sau.com.au/forums/topic/3148-rockingham-lines/#findComment-53998
I'm THERE!!
if i forget, and it's 8pm and ur there, just SMS me :D
i'll put it in my calendar anyway.. where's GOT BOOST gone ?
https://www.sau.com.au/forums/topic/3148-rockingham-lines/#findComment-54052
got aftermarket front pipe after cast turbo outlet 3" cat
and made 3" cat back with staright through staino muffler
from Mr Mayhem. sounds awesome and feels good too
i'll take it back to Formaz soon to compare HP.
mick at formaz was suprised at the first HP reading
and how strong it came on boost...
https://www.sau.com.au/forums/topic/3148-rockingham-lines/#findComment-54403
Originally posted by red17
Better add another line to the list of Rockingham ones. My R32 Gun Grey GTSt, currently sporting dealer plates until tomorrow.
Fresh off the boat :D
Its a bit of a step up in power from my old Pulsar SSS, enjoying every minute of it!
Red17
NICE!
Oh yeah. To anyone interested in the Motorplex. I'm going down on the 15th.... a
https://www.sau.com.au/forums/topic/3148-rockingham-lines/#findComment-55650
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
