Hi Guys!
After some time, i finally have enough moolah to start building my dream carputer.
Atm i'm just doing the research, gathering up ideas and collecting advices from veteran carputerers? :D
The purchasing, setup and install should be ok, but i need to know how to properly mount the touch screen LCD on the cubby hole on top of the A/C controls.
I've looked around on the net, and find that some G35 drivers have used a conversion kit to mount the lcd. I cannot for the life of me find this for sale anywhere.
I'd like to hear from anyone here who succesfully set up their carputer. Some pictures would be awesome as well especially the LCD part :laugh:
https://www.sau.com.au/forums/topic/314854-carputer-advice-needed/
Hi Guys!
What about an iPhone / Touch (or maybe better still an iPad when released) and ODB2 interface with REVS app or similar;
. Edited by Arcos
Actually, i've already got a double din setup. So playing MP3s. divx and dvds is no problem. But that iPhone obdII interface looks awesome! How much for the device?
I checked this website and it seems that this fella got the lcd mount and frame from a dude called 'god of cpu' over at g35driver forums. But he charges an arm and a leg for it. Over $600 with the lcd!
http://www.bluevalhalla.com/gallery/v/geek/g35carputer/
@ G33K can you post a few pics so we can see your setup?
@ Chris Would you have anything to mount the lcd for sale? Or maybe the touch screen itself?
What's wrong with the 'Reply' function? The typing cursor vanished making it hard to reply or post a new topic? Is it just me?
@ Chris When you said that i could hang my own screen on the stock popups, did you mean actually removing the lcd from my current housing and snap it inside this one? Cause that would be a state of awesomeness! How much bro?
@ Arcos. Interesting links mate. Thanks
I have a spare frame here. $40 and its yours. I have the screen out of already. (it is my programming jig for the lang swaps.)
now bear in mind that if yours is non navi you will need the frame as well.
Thanks for helping out.I'm interested. I've got a non navi v35. All i got is the cubby hole on top of the ac controller. Will this frame fit in it? Not too clear on how this frame actually looks like.Mind showing me a pic of it? Or a link to a website that has one will do :devil:
Cheers
@ Chris
I'd like a photo too for a non-navi edition? Are you suggesting you can supply the popup section of the navi edition minus the screen etc., i.e. just the fascia?
@ dodes47
This was my original post...let me know if you need a hand
http://www.skylinesaustralia.com/forums/Ca...ml&hl=carpc
Video of my OBDII setup, this doesn't show you the GPS/Video/Movie setup but you get the gist - http://tinypic.com/player.php?v=oqaj5f&s=3
<br />@ Chris<br />I'd like a photo too for a non-navi edition? Are you suggesting you can supply the popup section of the navi edition minus the screen etc., i.e. just the fascia?<br /><br />@ dodes47<br />This was my original post...let me know if you need a hand<br /><a href="http://www.skylinesaustralia.com/forums/Carputer-Install-V10-t261099.html&hl=carpc" target="_blank">http://www.skylinesaustralia.com/forums/Ca...ml&hl=carpc</a><br /><br />Video of my OBDII setup, this doesn't show you the GPS/Video/Movie setup but you get the gist - <a href="http://tinypic.com/player.php?v=oqaj5f&s=3" target="_blank">http://tinypic.com/player.php?v=oqaj5f&s=3</a><br />
<br /><br /><br />
@ Arcos, That looks wicked. Kinda beats the purpose of mobile computing a bit though, don't you think?
@G33K Thanks Tim, Nice setup. what is supporting your screen? Have you got some sort of frame or mount behind that lcd? Does it slide back into the cubby hole when not in use?
@Chris, you kinda lost me there mate. What does this navi framework look like? Excuse my ignorance.
@dodes47 Metal bracket in a sort of L shape.
It doesn't slide back in, as the casing wasn't deep enough to have it slide, so instead, i've made it removable. In that, i can take the whole screen out, put in my bag, close the lid and it just looks like a cubby from the outside.
Cheers
Luckily for me, the company i work for has a factory - metal and such
Its a thin, polished bit of steel, which i bent on a table, and then shoved in the "brace/slide slot" at the back of the screen.
Its a bit hard to describe, if you're at the next meet though, im happy to show you.
It all depends on the monitor that you decide to fill your cubby with, or if you go with double din, it vastly changes the setup.
Ok guys, i finally finished the carputer! In the end, i decided to use my eeePC that was lying around, just until i can build a proper one with enclosures and all.
I mounted the eeePC inside the boot and the cables run on the left side of the car. At first i was concerned about air circulation, but found out on max load the temp hovers between 21-23 degrees. Cool
There is a remote power switch under the dash to control the computer's power.
I had to cut a round hole behind the cubby box so the vga cable can get through. Not too happy about this, but it had to be done :)
I've set up the power option to hibernate 1 minute after the "ac" connection is lost so all i have to do is turn off the car and walk away. I push the button to turn it on.
I'm running windows 7 home premium (r7lited) cause the power option and stability is better. With Centrafuse 2.1 as the frontend. iGo 8 is my current gps software.
Took me 2 weekends and 8 cans of redbull to get the job done :P
Here's the parts breakdown and how much it costed me.
* eeePC 901 $275
* 7" touch screen LCD $170
* Gosget USB GPS $40
* Laptop car charger $8
* 5m Cigarette lighter extender $12
* Cigarette lighter 3 way splitter $5
* 2 x 5m USB Cable $15
* 1 x 5m VGA Cable Free
* 1 x 5m RCA Cable $10
Not to forget the hole cutter, glue gun, mounting strips and other stuff i needed to buy to get it done.
Total : $550
Here's some pics
http://i869.photobucket.com/albums/ab251/d...4390_377701.jpg
http://i869.photobucket.com/albums/ab251/d...4390_377700.jpg
http://i869.photobucket.com/albums/ab251/d...4390_377702.jpg
Next project : Setting up OBDII and Voice control.
Tim, i was hoping you can point me to the right OBDII usb interface to use. There's so many out there!
Comments and suggestions are welcome :sick: Thanks guys and sorry for the massive post and pics! Too excited ;D
Good work!!
What did you use to brace the screen up?
Also, how do you power the PC up?
Do you have to go to the boot and push the power each time?
As for the OBDII - get the BlaZt.biz cable, it'll give you everything you need as far as cables are concerned
If you're after something more advanced, i sell an OBDII HUD with TPMS Speed/Rev/Battery Volt/Engine Temp and so on.
Cheers.
Good work!!
Cheers.
Thanks
The screen came with a sliding mount at the back of it. I just reversed it and screwed it in to the cubby hole. There's already a hole on it anyways so i thought what the heck :)
As for the power, i opened up the eeepc and soldered two thin wires to the power button. If the cables get shorted, the computer turns on. So i just extended the wires and connected it to a $2 Jaycar button on the bottom of my dash.
The laptop is powered by a normal car charger with an 8 amp fuse just in case .
I saw that obd2 somewhere on the net. If i recall, they're selling it for $135 usd. Now i don't mind paying that much, but just curious, will this work? http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
If it does why the massive price difference?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
