Nah they dont look like that ^ and they say Xenon but you cant see it in this pic.
I have only ever had Cut H7s in it, and thats what was in it when I purchased the car.
Trimmed H7's is what I used when I did a dodgy conversion job to pass Regency (as I run D2R xenons - that's what came with the car when I bought it - freshly complied).
(Side note: I'm sure I already replied to this earlier with pretty much above - but my post seems to have gone missing...)
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5167411
This is what I have been using.
Dont H1s have a different plug thing?
I want to buy some new bulbs tonight hopefully. Just not sure what to ask for.... do the D2R lights come in all different sizes or do I just say D2R?..
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5169957
D2R xenons are very expensive over the counter; You could be talking $200-300 for a pair, easy. Getting them online is a lot cheaper.
However - this assumes you still have the xenon ballast, cabling, plugs, etc to hook it all up to.
A D2R bulb looks like this:
... totally different plug to what you have now. But the base (with trimming), and the light source of the bulb is about the same as a H7 bulb (which is why they're sometimes used for compliance purposes, I believe).
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5170021
Ill have to check if I still have all the stuff to plug them into. Not sure I do... will check tonight.
Might have to do the trimmed H7s again for now! I hate driving with one headlight. Make my car look pov. Hahaha
https://www.sau.com.au/forums/topic/315534-r34-headlamps/#findComment-5170163
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
