:D
Just got back from the movies tonight and at some stage during the 2 hours or so we were in there someone nicked the number plates of my mate's car... front and back!
Must've taken them a few minutes and I was (still am) completely dumbstruck that someone could stop in a shopping centre car park (sunnybank) and carefully remove both number plates from a car parked in a very visible spot without someone interrupting them.
Anyway, we stood there for a few minutes totally stunned by all this, then discussed whether he should call the police to report it. Ended up deciding they wouldn't be able to do anything much anyway so we both got in our cars and left... just as we were leaving the carpark a police car was coming in - first time I've ever seen one cruising around there. It chucks an immediate u-turn and pulls my mate over... yeh, no-one's around to see the plates get nicked but the police turn up after we'd gone less than 100m!
My mate wasn't too worried about the plates, even though they're unique (6-letter) personalized plates - he's confident he'll get a replacement set for little or no cost. He was just glad they didn't key the car in the process... Plus, at least the police ended up knowing about it, so the thief will never be able to use them on a car (trust me, they attract attention - a little too much)... they'll probably just turn up on ebay, or the thief will just try to impress his mates/boyfriends with them.
https://www.sau.com.au/forums/topic/31566-ballsy-thieving-bastards/
So they use the plates and a lookalike car for an armed robbery.....then make a clean getaway while a bunch of nervous heavily armed cops are surrounding your house.... Best of luck mate.....yeah it's not worth reporting to the cops
But yeah, that carpark is hopeless. We put a carboard/excel bodykit on our mates sigma there one night, took us a good 15mins, no one said a bloody word. And it wasnt a small cardboard kit either... Just dont park at GrandPlaza for more than 5mins.
Sunnybank carpark! You just said it in one go...my GF works at the centre..she had her car keyed the other week.
It just takes too much effort to watch your car while picking up the GF and make sure the trolley boys aren't ranskacking your stereo. It plain sucks in that place!
Dan
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
