yep, already too many of them involved in accidents.. and then being classified as "high performance cars" and then the cops are after them..
i mean.. sure you can drive like there is no tomorrow.. but think about us :D... i bet when i get the money to have a good car that -might- be "hi performance" they would be outlawed..
https://www.sau.com.au/forums/topic/31595--/#findComment-638393
yep i was been a fool b4
so i learn it the hard way
i mean...its sad to see others to learn the hard way as well...
i call him moron coz he didnt estimate the power of the car...and try to be a hero maybe...what u get out of it is pain and lost....not worth it...
if u wanna keep it...treasure it...
https://www.sau.com.au/forums/topic/31595--/#findComment-639571
ST.KILDA ROAD as everyone knows is very busy and considering not one of you saw the actual accident i consider u take time out and fink dat maybe it wasnt his fault!!! i dont know anyone that would drive an r34 recklessly, unless off coarse der loaded in which case i belive dey can drive it how evah dey want, crash it wen evah dey want, as long as der not endangering anyone else or their own lives!!! but any way lets not all jump to conclusion and just hope the driver n passangers of the car are ok da car will get fixed im sure....... :goddam: ohhh and by the way if it was there fault n if they were driving recklessly then vikii ur right their MORONS :rofl:
https://www.sau.com.au/forums/topic/31595--/#findComment-639969
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
