Hi guys,
So my motor is on its way out so im stripping the DE+T bits as i am rebuilding and chasing for more power.
Good chance for you NA boys to get some boost into your car.
1) $500
Turbonetics T3/T04E turbo with 3" inlet.
.50 A/R
Oil cooled (no need for messy water lines)
excellent condition, no shaft play & does not blow smoke
5 bolt style rear housing with custom made dump (weld onto your own front pipe)
Rear housing has been modded to fit 38mm external gate *****may be able to supply a IW rear housing****
**pics of wastegate fitted is at the bottom**
2) $60
Custom alloy intake from TB > cooler pipe with bov mount welded on (RB style flange) sprayed black for stealth look
3) $50
Custom braided oil line to suit turbo > oil pressure sender side of engine + Tee piece fitting
4) $80
R34 GTT injectors
5) $80
R33 GTR fuel pump (great upgrade for any skyline GTS/GTST/GTT)
6) $50
600x300x75mm intercooler core, minor bent fines but can easily be fixed with pliers
7) $200
38mm turbosmart ultragate with 7psi spring + screamer (heat wrapped with exhaust wrap)
8) $30
Stock RB20/25DET manifold
9) $80
RB25DE/T Green label AFM
This kit came off a R34 GT so will be a direct bolt on to a R34 RB25DE, i assume it would be the same/similar for a R33 RB25DE.
Willing to sell as a package or parts on their own.
Package price;
Turbo,gate/screamer, custom dump, custom braided oil line for $700
At 14psi, it made 210rwkw @ 550nM of torque, tuner said there is heaps more room for power but i was limited by the stock injectors, AFM & NA compression.
Located in Sydney, Pics upon request of other items.
Postage is not a problem, contact for prices.
Video of it in action;
PM if interested.
Thanks
  • 3 weeks later...
manifold & intercooler sold
UPDATE of whats left!!
R34 RB25 AFM $80
Custom front pipe $50 - just needs to be flanged on dump side, Suit R33/R34
R34 RB25DET NEO Stock injectors $80
Apexi Pod filter $50
Cheers
